89 Si swap
Old Jun 27, 2005 | 07:04 PM
AccordB20A5's Avatar
Default 89 Si swap
I am swapping a 1989 Honda B20A5 Prelude Si Motor into a 1993 Honda Accord. The block is to be Bored from 81mm to a 84mm, and the heads, intake, and header are ported and polished. A mild stage 1 cam is to be installed. I need to know if the 1993 Accord ECU can be changed to run the DOHC motor I will be running or will I have to re wire everything.
Jack Gilchrist
Nov 14, 2016 10:49 PM
Jack Gilchrist
Nov 14, 2016 10:34 PM
jdmtim27
Feb 28, 2011 10:33 PM
