zc swap,it truns over but no spark help and check engine glows
ok we just swaped a zc obdo into a 90 civic si HB and it turns over but know spark.
when you turn the key on i hear a clicking noise and it sounds like its comeing from the main relay. also when you turn the key on the check engine light kind of glows and flash a lil bit and the ecu does the same. i dont have a clue what this could be please any info would help.
Is the ECU throwing a code? If so reference it with this list: http://tech.hybridgarage.com/tech/codes.html
What ECU are you using? PM6 or a PM/PG7?
check your main harness ground that bolts to the thermostat housing
thanx thats what it was
b17 turbo
May 7, 2008 11:28 PM
cdescoteaux
Dec 21, 2006 10:05 AM
