Motor Mount Modification?
Old Jun 27, 2005 | 04:48 PM
EKIM NART's Avatar
Default Motor Mount Modification?
I plan on getting a 90 dx hatch but its an automatic. Will I need tho modify any of the motor mount brackets before i convert to a 5 speed.
Old Jun 27, 2005 | 04:49 PM
vegaskurt's Avatar
Default Re: Motor Mount Modification? (Ef2Ls)
The rear, passenger side, and front mount are different on the autos. You can probably get the front to work but the rear and side are another story.
Old Jun 27, 2005 | 06:15 PM
bagpipe goatee's Avatar
the chassis mounts are all the same. well, except for the rear one, but that one's not part of the car, its on the crossmember.
the motor mounts themselves are different, though.
Old Jun 27, 2005 | 06:21 PM
91whiteZCrex's Avatar
Default Re: (bagpipe goatee)
i did the good old auto to emanual. the only one that you can still use is the right side (drivers) you will need to get a new bracket for the back. or at least from a junkyard. but yea. depends what motor your puttin in. if you are going b-series dont worry about tthe front you dont use it.
Old Jun 28, 2005 | 03:49 PM
EKIM NART's Avatar
Default Re: (91whiteZCrex)
what about the tranny side? what modification will i need to do?
Old Jun 30, 2005 | 08:27 AM
Default Re: (Ef2Ls)
the rear bracket and mount, and the left mount. you need to get those. from a 5spd from the junkyard or sumttin
DarKStaR5
Mar 6, 2008 08:08 PM
boostin4door
May 23, 2005 04:41 AM
EJCivJdM93
Feb 9, 2005 04:40 AM
onyx00
Sep 24, 2004 01:00 PM
oldbeefcake
10
Mar 25, 2004 08:39 AM
