What The Hell !!!!!!!!!!!
From: Murfreesboro, Tennessee, United States of America
Okay i my car runs great when i drive it hard but normal driving it runs shitty and at idle it revs for 800-1300. There seems to be oil on the bottom ot the spark plugs or it could be gas. but it is running rich as hell and the spark plugs are black it was throwing code 1 and 9 but after i reset the ecu and drove it it did fine no codes.
My set up is a DOHC ZC turbo run with turbo edit
it ran find until i changed the head gasket
compression test check out good
new HKS metal head gasket
new valve cover gasket and o rings
a/f is running lean at idle like 11.2 or so
but i don't think my o2 is working cuz it reads .92 volts all the time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer »</TD></TR><TR><TD CLASS="quote">Okay i my car runs great when i drive it hard but normal driving it runs shitty and at idle it revs for 800-1300. There seems to be oil on the bottom ot the spark plugs or it could be gas. but it is running rich as hell and the spark plugs are black it was throwing code 1 and 9 but after i reset the ecu and drove it it did fine no codes.
but i don't think my o2 is working cuz it reads .92 volts all the time</TD></TR></TABLE>
11.2 at idle isnt lean, its pig rich, you need a better tune
My tune is fide the car ran prefect before i changed the headgasket.
what could make it run the rich?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer »</TD></TR><TR><TD CLASS="quote">what is the pcv</TD></TR></TABLE>
*Sigh*
*Sigh*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9eDDie »</TD></TR><TR><TD CLASS="quote">
*Sigh*</TD></TR></TABLE>
helps a lot, ***
just tell me wtf it is
*Sigh*</TD></TR></TABLE>helps a lot, ***
helps a lot, ***
just tell me wtf it is </TD></TR></TABLE>
never mind i found what that was
but what about it running rich
helps a lot, ***
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer »</TD></TR><TR><TD CLASS="quote">helps a lot, ***
the reason why i didnt have any sympathy for u is that...i hate ppl that do all this stuff to their cars but know nothing about them...it seems like u just mod ur car cuz its wut "Everyone is doing"
No i know a good amount about Honda's and am will to learn more i knew what a pcv is and dose it just didn't cross my mid as to what it was called till i saw it
and for the ppl that do mod out there car and don't know any thing about them and are willing to learn isn't that what this site is for learning and helping those in need? there was a time when you your self didn't know **** about cars.
any ways that is not what this is about and i am sorry for being rude it just gets to me when ppl on here think they are the **** and can down talk to others about a fairly good question but you are right i should have to the time to search my bad
So if we can ... Back to the topic
last night i checked the tuning on my ecu and its all still good should run like it did before but it runs rich as hell to the point to where if i let it run then pull out the plug they are dripping in gas.
gonna replace the pcv and o2 today
what can i look for along with this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer »</TD></TR><TR><TD CLASS="quote">My tune is fide the car ran prefect before i changed the headgasket.
what could make it run the rich?</TD></TR></TABLE>
Your tune is obviously not fine if you are running so rich. What are you using to "tune your motor"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">
Your tune is obviously not fine if you are running so rich. What are you using to "tune your motor"</TD></TR></TABLE>
turbo edit
i put my stock ecu in and it ran rich at idle as well and the car ran great before i did the head gasket
fule pressure gauge reads like 40 at idle and when i take the vacume line off it only jumps to 43 or so
turbo edit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive »</TD></TR><TR><TD CLASS="quote">Timing</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer »</TD></TR><TR><TD CLASS="quote">Timming as in on the dizzy, timing for boost or timing on the timing belt </TD></TR></TABLE>
Check all of the above, you can set it to advanced to retard from the dizzy
I checked the timing on the belt and it is good
I played with the timing on the dizzy and it chaged the sound but not the richness
and i ran my stock ecu and it still runs funky
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer »</TD></TR><TR><TD CLASS="quote">I checked the timing on the belt and it is good
What number did you get when you checked the timing on the belt? it should be +16 I believe
Don't jump to conclusions. He is asking for help with his car not running right. You don't know about his situation besides the fact that he is asking for help. And what help are you offering him? I didn't see any.
Also, he seems like he knows how to troubleshoot pretty damn good. Most people in the your particular "classification" would just take their car to a shop. And if they came on here asking for help, they would sound like a complete moron and just say "Help, my car isn't running right!" and that would be it. No clues as to what is wrong. Nothing! That obviously isn't the case in this situation. So why don't you take your great 2005 knowledge elsewhere.
</TD></TR></TABLE>Don't jump to conclusions. He is asking for help with his car not running right. You don't know about his situation besides the fact that he is asking for help. And what help are you offering him? I didn't see any.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer »</TD></TR><TR><TD CLASS="quote">How do i get a number?</TD></TR></TABLE>
So are you saying you check the timing belt with out a timing gun? You get a number from a timing gun
no i check for top end center to be lined up with the cams but i am going to a friend house right now cuz i cant find my timing light
