i searched! ZC into DX code 10,19,20
Old Feb 13, 2002 | 10:58 AM
l's Avatar
l
Default i searched! ZC into DX code 10,19,20
hery i have a CRX that i swapped a ZC into ..... the motor before the ZC was a LS Vtec and the engine before that was a b16 i believe... so its wired for the goodies.. however im flashing these 3 codes.....
i was wondering if you guys could help me out by determining the problem...
also the car will not crank over
Old Feb 13, 2002 | 11:21 AM
wronghand's Avatar
Default Re: i searched! ZC into DX code 10,19,20 (IM ALL SHO)
10 - Intake Air Temperature
19 - Lock Up Control Solenoid (Automatic Transmission Only)
20 - Electric Load
What ECU are you using?
Old Feb 13, 2002 | 12:03 PM
l's Avatar
l
Default Re: i searched! ZC into DX code 10,19,20 (wronghand)
im using an 88-89 integra ECU...
seeing that code 19 is an auto im hoping the ECU isnt automatic however ill get the SI ECU and try that to see if the code goes away..
how do you get rid of 10 and 20?
Old Feb 13, 2002 | 12:08 PM
Mugen Dom's Avatar
u got urself a auto ecu change to a pm7 manuel ecu and then see wut happens after that teh intake air temp senser is on the side of the intake manifold and teh eld is sensing an electrical load but it may be ur ecu is bad also
phatrick2332
Apr 29, 2004 11:33 PM
JapJunkie
Mar 22, 2004 11:05 AM
rschoener
Aug 17, 2003 08:48 AM
tdc
Feb 23, 2002 08:32 AM
Xbuilt2lastX
Oct 15, 2001 10:55 AM
