d16z6 into ef9 civic, problem starting up.
Old Jun 27, 2005 | 03:25 PM
handa's Avatar
Default d16z6 into ef9 civic, problem starting up.
Recently swapped a d16z6 into my EF9. I'm having problem starting it up. The motor cranks and it seems to want to startup. It has gas because I can hear it. I checked the sparks and there were sparks.
Here is my setup:
D16z6 w/ d16a6 ecu
d16z6 obd1 distributor w/ obd0-obd1 conversion
is it the ECU? Please help me out. Thank you
Old Jun 27, 2005 | 03:35 PM
FaceTuned's Avatar
D16z6 w/ d16a6 ecu
thats your prob!
Old Jun 27, 2005 | 03:38 PM
Mach69's Avatar
Default Re: (jdmhatchness)
Can't use the A6 ecu with an obd-1 distributor. You need to buy a p28 ecu!
Old Jun 27, 2005 | 04:38 PM
handa's Avatar
Default Re: (Mach69)
thanks guys. i answered my own question, but i just wanted to confirm.
Old Jun 27, 2005 | 07:39 PM
thumbtack's Avatar
Default Re: (handa)
how did you manage to use a OBD0 ecu with an OBD1 conversion? The plugs are not the same. What all have you done to convert to obd1. you need a conversion harness to be able to plug in a p28...
KURUPTinc
Sep 4, 2005 08:41 PM
Conclusive
May 30, 2005 11:06 AM
IDGAF2885
Sep 25, 2003 04:39 PM
B_1_8_hatch
Jul 30, 2002 07:06 AM
