My injectors are maxing out, what should I do?
Old Jun 27, 2005 | 03:10 PM
abmerop18's Avatar
Default My injectors are maxing out, what should I do?
I have a 2002 Civic turbo and I am using RSX-S injectors which are 330cc compared to the stock 240cc injectors, but I am still maxing them out. Here is the datalog from my e-manage. This is a pull from 1st gear through most of 4th. As you can see, they max out at higher RPM and what seems for almost all of 4th gear. What should I do?
Old Jun 27, 2005 | 03:14 PM
dustin's Avatar
Default Re: My injectors are maxing out, what should I do? (abmerop18)
how about get larger injectors?
Old Jun 27, 2005 | 03:19 PM
dc2legend's Avatar
Default Re: My injectors are maxing out, what should I do? (dustin)
Get some 550s in that.
Old Jun 27, 2005 | 03:35 PM
MooreBoost's Avatar
Default Re: My injectors are maxing out, what should I do? (dc2legend)
Buy larger injectors.
Old Jun 27, 2005 | 04:12 PM
donkiman's Avatar
Default Re: My injectors are maxing out, what should I do? (MooreBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost &raquo;</TD></TR><TR><TD CLASS="quote">Buy larger injectors. </TD></TR></TABLE>
Old Jun 27, 2005 | 04:17 PM
HiProfile's Avatar
Default Re: My injectors are maxing out, what should I do? (donkiman)
I'd say crank the fuel pressure, but it usually works out to 4x the psi for 2x the flow. My guess is that you'll still be maxing them even if you max your fuel pressure (against safe limits).
Turbo DSM's (5spd) came with 450cc's if you've had your head in teh ground this whole time, they just need a resistor box.
Old Jun 27, 2005 | 04:45 PM
Antilag's Avatar
Default Re: My injectors are maxing out, what should I do? (HiProfile)
450 or 550 saturated injectors.
97turboteg
Apr 2, 2006 07:59 PM
DeadVet
Oct 22, 2004 03:22 PM
ATS*Mark
Aug 18, 2004 09:16 PM
B_1_8_hatch
Sep 12, 2003 11:23 AM
b16powwer
Aug 15, 2003 12:07 AM
