How far does the Prelude thermostat open?
Old Jun 27, 2005 | 02:50 PM
kb58's Avatar
Banned
Default How far does the Prelude thermostat open?
I tested mine, putting it in hot water. While it opened, I don't know if it opened far enough to be considered good. How far it must open? 1/8"?, 1/4"?, 1/2"?, 1"? A Honda Tech would know this.
Old Jun 27, 2005 | 06:24 PM
eMpAtHy's Avatar
Default Re: How far does the Prelude thermostat open? (kb58)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 &raquo;</TD></TR><TR><TD CLASS="quote">I tested mine, putting it in hot water. While it opened, I don't know if it opened far enough to be considered good. How far it must open? 1/8"?, 1/4"?, 1/2"?, 1"? A Honda Tech would know this.</TD></TR></TABLE>
i have the failsafe ones from autozone that i will sell to you for 5 dollars. i used it for 1000 miles. parting out my car and i dont need it anymore.
i never cooked a thermostat, so i dont know how big it opens.
Old Jun 27, 2005 | 09:16 PM
brolli's Avatar
Default Re: How far does the Prelude thermostat open? (eMpAtHy)
dont go cheap and buy from autozone get the origional honda thermostat. they are made a whole lot better and the extra ten bucks or so it definately worth it. it will fit better seal better and work a lot better than aftermarket ones do. most of the time aftermarket ones will work just fine but i've ran into a few times where a new one iether wont open far enough or doesnt open soon enough and causes overheating. i installed the origional part and it kept the temp perfect. well when you cook a thermostat you need to slowly heat the water and record the temp that it started to open and when it was full open. it should start to open about 20 degrees less than what its rated for and be full open about 10 degrees over what its rated for. the farthest i've seen them open is about 3/4 inch.
Old Jun 28, 2005 | 11:07 AM
00MugenLude's Avatar
Default Re: How far does the Prelude thermostat open? (brolli)
Standard Thermostat
Lift height: above 10mm (0.39in)
Starts opening: 169 - 176 degrees F
Fully open: 194 degrees F
from Helms manual.
Old Jun 28, 2005 | 11:10 AM
eMpAtHy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brolli &raquo;</TD></TR><TR><TD CLASS="quote">dont go cheap and buy from autozone get the origional honda thermostat. they are made a whole lot better and the extra ten bucks or so it definately worth it. it will fit better seal better and work a lot better than aftermarket ones do. most of the time aftermarket ones will work just fine but i've ran into a few times where a new one iether wont open far enough or doesnt open soon enough and causes overheating. i installed the origional part and it kept the temp perfect. well when you cook a thermostat you need to slowly heat the water and record the temp that it started to open and when it was full open. it should start to open about 20 degrees less than what its rated for and be full open about 10 degrees over what its rated for. the farthest i've seen them open is about 3/4 inch.</TD></TR></TABLE>
i was boosted and i live in so. cal and i was fine with mine from autozone.
Old Jun 28, 2005 | 07:47 PM
brolli's Avatar
yea i was just saying that the likelyhood of getting a defective thermostat from autozone is much higher than buying a honda one.
Old Jun 28, 2005 | 09:00 PM
kb58's Avatar
Banned
Thanks guys, I think I'll get one from Honda... or Majestic... I didn't know that was in the Helms
Mr2u53
Mar 22, 2014 12:51 AM
preludeSRV
Apr 23, 2008 08:34 AM
blinger
Apr 26, 2007 10:21 AM
budget
Apr 8, 2005 09:47 PM
jakers
Dec 17, 2004 04:36 AM
