general question about check engine (self diagnostic system)
Old Jun 27, 2005 | 01:55 PM
clash's Avatar
Default general question about check engine (self diagnostic system)
I'm thinking about situation like this:
when I do the self diagnostic procedure- the service checked connector is jumped and there is no errors in my car
the check engine shoud stay still on
or it shoudl stay off?
civic 94 d16z9
Old Jun 27, 2005 | 05:11 PM
unknown0001's Avatar
Default Re: general question about check engine (clash)
You jump the service connector while the car is off, turn it on and wait for codes
if no codes come up the ECU isn't seeing any problems. If it does come up with a code then refer to this
https://honda-tech.com/zerothread?id=1171263
Old Jun 27, 2005 | 10:52 PM
clash's Avatar
Default Re: general question about check engine (Mr.RHTuner)
I know how to do the self diagnostic and how to read the codes
but what about the situation when I jump the service connector and the check engine light stay still on?
is it correct?
check engine shouldn't stay off?
Old Jun 28, 2005 | 04:19 AM
JimBlake's Avatar
On my '95 Integra, with no codes stored, the CEL comes on solid when you jumper the connector. For example when checking spark timing...
If the CEL doesn't come on at all (after ruling out a burned-out bulb) that's code zero, which is supposed to be a fried ECU.
Old Jun 28, 2005 | 07:05 AM
EE_Chris's Avatar
Default Re: general question about check engine (JimBlake)
On my 99 Civic, the CEL behaves the same way as Jim describes.
Old Jun 28, 2005 | 11:50 AM
Chiovnidca's Avatar
Default Re: general question about check engine (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">On my 99 Civic, the CEL behaves the same way as Jim describes.</TD></TR></TABLE>
All obd1 and obd2 models do the same.
Heybeyotch
Feb 25, 2013 11:26 AM
Bambinoh
Apr 6, 2008 05:14 AM
jeux
Jul 10, 2004 08:40 PM
johnzm
Sep 13, 2002 02:39 PM
