Suspension Guru's How do I get more negative camber with these camber plates???EP3
As you can see in this pic..I am able to squeeze out an additional -2.0 or -2.5 neg camber in the front..but the allen heads are hitting the frame..Is it possible to use like flathead screws or bolts so it can adjust further? Thanks, in advance
would like a flat head hex nut work? Just need something that can slide under the top hat without hitting, so I can adjust the strut towards the engine more = more - camber..These things will go to -6 degrees and I am only at -3
James89DX
11
Jun 8, 2009 11:26 AM
