92 prelude rotor removal
I have a 92 prelude and I was wondering if anyone knows how to change the rotors on it I had a 91 accord and i had to take my hub to a mechine shop to get them pressed out is it the same for a prelude???????????????
1. Remove Caliper (2 bolts)
2. Remove Caliper Bracket (2 bolts)
3. Remove Set screw
4. Pull rotor off. (note: might need light tapping with a rubber mallet to loosen up some rust-- pb blaster also works for breaking rust)
you can include steps 1 and 2 if you'd like, being that the caliper will come off with the bracket.
3. Remove Set screw
mjolson
Dec 23, 2010 11:58 AM
