Suspension & Brakes Theory, alignment, spring rates....
need help with my omni
Old Jun 27, 2005 | 08:35 AM
B18CR-X's Avatar
Default need help with my omni
i just purchase my omni full coilovers for my 89crx hf, but i ran into a problem. the box they came in it said there where for dc and eg models but the guy at the shop i got them from there the same suspension for and ef. the rear fit fine but the front did not fit inside the front fork where the strut sit. my question is can i swap front fork of and eg into my ef.
Old Jun 27, 2005 | 10:17 AM
Tyson's Avatar
Default Re: need help with my omni (B18CR-X)
you can swap forks. but youll run into an issue of not properly lowering the fronts. its a known problem with omni, and i hear recently theyre doing something about it.
you should have told the shop to replace the kit and give you the right ones. they informed you wrong.
Thategdude
Suspension & Brakes
Dec 5, 2016 11:41 PM
LS94tegra
Sep 22, 2008 09:26 PM
Mugzy909
Sep 1, 2008 10:29 AM
superhatchbackbros
10
Feb 8, 2008 11:22 PM
SpoonyGSR
Suspension & Brakes
May 3, 2005 03:29 AM
