P28 ECU Strange Fuel Control
Old Jun 27, 2005 | 01:27 AM
cord4530's Avatar
Default P28 ECU Strange Fuel Control
Hey all,
I have a stock 93 si with a D16Z6 and P28 ECU. I recently installed a wide band air fuel ratio meter, and under part throttle (cruising) the AFR is all over the place. Usually bouncing between 13 and 15:1. It tends to sit down around low 13's most of the time, and maybe once per second it bounces back up to 14.5:1.
At first I thought maybe an injector was off, or there was a misfire or something. But under full throttle, it sits at a rock solid 13.6:1. Also, For a day I ran with the O2 sensor unplugged and the AFR was a solid 14.2:1 No bouncing at all.
AFR did the same with old O2 sensor, and new one. Is this typical, or is there something strange here?
--Dan Cordon
ef9allday
Mar 22, 2013 09:46 PM
ekcivic2
Engine Management and Tuning
Jun 19, 2010 09:59 AM
variable
Oct 16, 2009 01:59 PM
Carbcivic
Nov 9, 2005 07:48 AM
SCsol
Apr 1, 2002 08:36 PM
