Car running lean, need help!!
Old Jun 27, 2005 | 01:15 AM
YodajdmEK4's Avatar
Default Car running lean, need help!!
I checked my spark plugs and the tip of 2,3,and 4 are white which indicates that car is running lean, I have 92 hatch cx with JDM Del Sol B16, the throttle body on it doesnt have a map sensor, what do I need to do and what would make it run lean???
Old Jun 27, 2005 | 01:46 AM
Stoich EG2's Avatar
Default Re: Car running lean, need help!! (casperjdmeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by casperjdmeg6 &raquo;</TD></TR><TR><TD CLASS="quote">the throttle body on it doesnt have a map sensor, what do I need to do and what would make it run lean???</TD></TR></TABLE>
you're a smart guy. TRY GETTING A MAP SENSOR...
Seriously... does that not make sense? I don't see how your car even runs right without one. i'll sell you one for $150
Old Jun 27, 2005 | 05:11 AM
97dxnut's Avatar
Default Re: Car running lean, need help!! (Advan06)
clogged fuel filter?
Old Jun 27, 2005 | 06:24 AM
vsmhatched's Avatar
Default Re: Car running lean, need help!! (97dxnut)
map sensor on my GF's 92 DX is on the firewall not on the throttle body, so i'm sure it gonna be the same for CX's but start with the fuel filter since the car is 13 years old.
Old Jun 27, 2005 | 01:16 PM
YodajdmEK4's Avatar
My fuel Filter is brand spankin NEW, my stock 1.5 had the map sensor on the throttle body and I rigged it onto my B16 but I heard that I need the map sensor that goes on the firewall, External map Sensor or new throttle body, I just want to confirm before buying
Old Jun 27, 2005 | 01:45 PM
komat's Avatar
Default Re: (casperjdmeg6)
my jdm b16a sir2 has white spark plugs
from what i been told its normal unless its super white
Old Jun 27, 2005 | 04:52 PM
YodajdmEK4's Avatar
Default Re: (komat)
It is bad if your spark plugs are white because you can blow your engine
Old Jun 27, 2005 | 04:57 PM
komat's Avatar
do a search next time then
https://honda-tech.com/zerothread?id=1247913
EgSalad
Jun 6, 2007 12:12 PM
civichatch67
Sep 21, 2005 10:11 AM
kechup2eg6
Aug 10, 2005 07:47 PM
b16delsol
May 17, 2004 09:06 PM
