b16 wiring DX harness confusion
hey guys, Im pulling a complete b16 swap out a DX CRX. its the exact same as my car except it has a b16 in it. Its wired up. and he says I can have the harness. The problem is I dont Witch harness I can use?
what i would LIKE to do is pull the harness from the ECU all the way up, so I wont miss anything.
But I dont want to do anymore work if I dont have too.
Its OBD0.
I know theres repining that needs to be done, but Can I take the entire harness with out having to pull the dash harness as well? thanks guys.
Its OBD0.
Nah..Keep your stock harness in the car..And take the mpfi parts and 4 vtec wires from the modifyed dx harness and add them to your harness..Then pin in the extra wires you just added to the ecu connectors..Just remember how it came off the other harness so its as easy as possible
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">Nah..Keep your stock harness in the car..And take the mpfi parts and 4 vtec wires from the modifyed dx harness and add them to your harness..Then pin in the extra wires you just added to the ecu connectors..Just remember how it came off the other harness so its as easy as possible</TD></TR></TABLE>
oh alright, that does sound easyer. Ill have to write notes down when im disconecting the wires. also note where the pins are moved too. Thanks bro.
Give us a call http://www.rywire.com and we will explain it to ya.
Ryan
Ryan
exist12
Oct 26, 2007 08:19 AM
nvalueff
Jan 6, 2006 07:10 PM
