Hunting idle??
Old Jun 26, 2005 | 07:59 PM
Shmolie's Avatar
Default Hunting idle??
I have a b16 swap i just put on a type r manifold. Had the problem before the manifold but got a lot worse after. The problem is hunting idle from 900rpm to 2500rpm once car is warm. When the car is cold it idles at 2500rpm (normal). I searched and found some things about the FICV so i checked that by plugging the hole(no suction). Nothing changed so i pluged the top hole (going to the IAC) lots of suction. When i covered that hole the car idle normal. Would that mean i have a bad IAC? or is there something else i could try?
Old Jun 27, 2005 | 05:37 PM
Shmolie's Avatar
Default Re: Hunting idle?? (Shmolie)
bump PLEASE HELP
Old Jun 27, 2005 | 05:59 PM
projectTeG's Avatar
try cleaning out your iacv with carb cleaner, clean out the are where the gaskets at....and if that doesnt fix the idle problem. take the Fitv off and screw the screw back in
Old Jun 28, 2005 | 05:37 PM
PrettyLude's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">try cleaning out your iacv with carb cleaner, clean out the are where the gaskets at....and if that doesnt fix the idle problem. take the Fitv off and screw the screw back in</TD></TR></TABLE>
and also bleed all your bubbles out of the coolant, check for vaccum leaks
Old Jun 29, 2005 | 05:58 PM
Shmolie's Avatar
Default Re: (PrettyLude)
i will give that a try thanks
fresheg760
Jun 7, 2008 06:33 AM
ek9child
14
Aug 22, 2007 08:10 PM
ExAcc
Sep 20, 2005 10:49 AM
