Opinions on the b16a????
Old Jun 26, 2005 | 06:46 PM
MrPink83's Avatar
Default Opinions on the b16a????
Does anyone have any opinions on the b16a. im interested in doin a swap in my 1990 civic and i think the b16a would be the most convenient and the most in-expensive motor. WAT DO YOU THINK?!?!?!?!
Old Jun 26, 2005 | 06:51 PM
SiR Inspired ED7's Avatar
Default Re: Opinions on the b16a???? (MrPink83)
B16a in my rex and i'm loving it, if your planning to turbo b16 is a known good way to go
Old Jun 26, 2005 | 07:04 PM
MrPink83's Avatar
Yeah???? good ive been trying to find sum good setups. im definately going to turbo it. Ive herd you have to lower the compression ratio tho.....
oh yeah have you herd of anyone getting one of those ssautochrome turbo kits because im lookin at getting one but it seems to good to be true
Old Jun 26, 2005 | 07:12 PM
KFBhonda's Avatar
you don't HAVE to lower the comp ratio, but it makes it a bit easier to tune, lowers the chances of detonation, and makes additional boost possible on stock sleeves, if you use forged pistons.
ssautochrome is too good to be true, b/c YOU GET WHAT YOU PAY FOR. but, some people have had decent luck with the wastegates and manifolds, provided that they relieved the mani of holding up the weight of the turbo. this is done by making a bracket to brace the turbo from underneath and have the engine block support it.
Old Jun 26, 2005 | 07:16 PM
MrPink83's Avatar
Default Re: (KFBhonda)
Yeah, eneryone has told me to support the mani cuz they eventually break but how are the actual turbos themselves, are they reliable???
Old Jun 26, 2005 | 07:18 PM
AWDspyder's Avatar
Default Re: (MrPink83)
I have only heard good things about the b16a. Should have my b16a complete swap kit for my 1g rex in about a month. hopefully
Old Jun 26, 2005 | 07:20 PM
MrPink83's Avatar
What is the maximum boost you think i could safely run through the b16a without any internal mods, just the stock b16a and the turbo set-up. is it a bad idea and if it is do you think forged rods and pistons would be enough? oh and how are the heads on them , strong enough to handle the additional power?
Old Jun 26, 2005 | 07:21 PM
Autoworks's Avatar
Default Re: (AWDspyder)
I love mine, but really all you have to do is search or scroll thru the forum, most here have B16s, not too many people complaining about the motor.
Old Jun 26, 2005 | 07:26 PM
MrPink83's Avatar
oh ya cool
well anybody have any answers to my questions above????
Old Jun 26, 2005 | 07:31 PM
B16CRXT's Avatar
I'm running 12 psi on my stock B16A with a T3 .48/.60 turbo and it pulls like a freaking beast.
if you want more than 300whp plan on upgrading the internals and sleeving or filling the block.
get a good FMIC. Stay away from SSAC kits. Their wastegates and BOVs are good from what I hear. I'm running one of their 38mm wastegates and its working great so far
Old Jun 26, 2005 | 07:35 PM
davidcrx89's Avatar
Default Re: Opinions on the b16a???? (B16CRXT)
my friend has an integra with a b16a1 and got his turbo in 6 days ago and it ran perfect before the turbo it was installed with hondata and it started smoking and all kinds of crank case smoke coming from the valve cover did a compression test and it was 100 170 80 190 its a an eclipes/evo 3 turbo with 7.8 pounds of boost what do you think happened
Old Jun 26, 2005 | 07:47 PM
B16CRXT's Avatar
Default Re: Opinions on the b16a???? (davidcrx89)
should have done teh compression test before the install.
Soudns liek he had a bad tune if it had a good comrpession before the install. No smoke for me
Old Jun 26, 2005 | 08:01 PM
AWDspyder's Avatar
tuning tuning tuning.
Old Jun 26, 2005 | 08:10 PM
turboJDMeg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrPink83 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, eneryone has told me to support the mani cuz they eventually break but how are the actual turbos themselves, are they reliable???</TD></TR></TABLE>
well how long before the mani actually cracks or breaks? month? two? a year? thanks
Old Jun 26, 2005 | 08:24 PM
MrPink77's Avatar
Not very long really. Its just the vibration of the motor that makes it crack
id say a month or two
Old Jun 26, 2005 | 08:26 PM
MrPink77's Avatar
Old Jun 26, 2005 | 08:30 PM
bspeed's Avatar
Default Re: (MrPink77)
over rated. Sohc vtec= same torque, cheaper, lighter(by 100lbs for the whole drivetrain) more respect when you wax a dohc car.
Old Jun 26, 2005 | 08:33 PM
B16CRXT's Avatar
Default Re: (bspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bspeed &raquo;</TD></TR><TR><TD CLASS="quote">over rated. Sohc vtec= same torque, cheaper, lighter(by 100lbs for the whole drivetrain) more respect when you wax a dohc car.</TD></TR></TABLE>
sorry, but a SOHC with mods will not beat a DOHC with the same mods in teh same car. bad advice =
Old Jun 26, 2005 | 08:35 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrPink77 &raquo;</TD></TR><TR><TD CLASS="quote">What is the maximum boost you think i could safely run through the b16a without any internal mods, just the stock b16a and the turbo set-up. is it a bad idea and if it is do you think forged rods and pistons would be enough? oh and how are the heads on them , strong enough to handle the additional power?
300hp or less with a good tune..Who gives a **** about boost..Im sick of people asking how much boost the motor can handle..You would have to give to give every single spec of the turbo you plan to run for someone to tell you how much boost you can run..
And dont worry about the head..You can make 600-700 maybe even 800hp on a stock head as long as you dont over rev..
Old Jun 26, 2005 | 08:36 PM
B16CRXT's Avatar
the question isnt how much boost. It's how much power and I wouldnt do more than 300whp on a stock B series. how much power you make depends totally on your turbo. get a dyno tune and be done with it.
slowman's Avatar
I took way too long
Default Re: (B16CRXT)
Can't really complain. I'm running 14.5 all day long with an intake and exhaust on a 1.6 L 4 cylinder engine.
Old Jun 26, 2005 | 08:52 PM
MrPink77's Avatar
Default Re: (Mr.speaker)
okay... im startin to get the boost thing, i should aim for power not boost.. good opinion
so what direction should i go in for 300whp goal?? with a b16a i have a mechanical background so feel free to give me the technicals
Old Jun 26, 2005 | 08:55 PM
crxnj's Avatar
Get the proper size turbo,intercooler,Good fuel managment and find a good tuner..Also make sure the motor is in optimal condition before you start modding..leakdown test,compresion test,tune-up,belts,etc....
Old Jun 26, 2005 | 08:56 PM
MrPink88's Avatar
The only thing to keep in mind is that i have a budget of about $3500 to $4000 including the price of the motor
Old Jun 26, 2005 | 08:59 PM
MrPink88's Avatar
Default Re: (MrPink88)
ok ok how reliable is hmotorsonline.com cuz i think im going to get the motor from there..
oh and what is an afordable direction for a turbo?
