Suspension & Brakes Theory, alignment, spring rates....
What size rod ends to get?
Old Jun 26, 2005 | 06:01 PM
Liquidgsr's Avatar
Default What size rod ends to get?
Trying to make a set of adjustable endlinks for my sway bar and i don't know what size to get. Can anyone help? They are staged in fractions. Is that the hole? If so what would be a good size to get for the stock sway bolts? This is for integra GSR with type r 22mm sway bar and nar spec LCAs.
Old Jun 28, 2005 | 12:05 PM
Liquidgsr's Avatar
Default Re: What size rod ends to get? (Liquidgsr)
anyone?
Old Jun 28, 2005 | 12:40 PM
CRX Lee's Avatar
Look at the racing supply shops like Truechoice, Racer Parts Wholesale, Pegasus, etc.. Also Alinabal and Aurora are among leading brand names if you want to Google them and find the threading and spherical ball sizes. The generic name (like Kleenex, Band-Aid, etc.) that rod ends or spherical bearings go by in Heim Joint so you could search that as well.
Old Jun 28, 2005 | 03:19 PM
Liquidgsr's Avatar
Default Re: What size rod ends to get? (CRX Lee)
yeah i have the truechoice catalog and im wondering what size i would need.
Old Jun 28, 2005 | 03:43 PM
CRX Lee's Avatar
I would go by whatever bolt size is convenient for you. If you are mounting them pretty vertically, I rather doubt you would run into an issue with any rod end being too weak and bending from sway bar force so strength shouldn't be an issue. The factory Honda bolts are I think 10mm so I would go with a bearing ID as close to that as possible.
Old Jun 28, 2005 | 04:17 PM
Liquidgsr's Avatar
ok cool...ill have to find that in the measurements that they have. Great. yah right now the angle is way off on my sway bar and its doing jack crap so i need to straighten it. Thanks for the help.
nghtshd88
Mar 4, 2012 02:32 PM
Charri
Sep 12, 2007 12:32 AM
DC2R714
Acura TL, RL & ZDX
Nov 4, 2006 07:22 AM
DC5-R
Aug 25, 2003 06:49 AM
