need to know what oil pump i can use
Old Jun 26, 2005 | 05:28 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default need to know what oil pump i can use
well i found my leak its my oil pump the 5th gen one cost alot i need to know if i can use one from a h23 or older h22
thanks for any help
Old Jun 26, 2005 | 05:30 PM
clemsoncb7's Avatar
Default Re: need to know what oil pump i can use (raylude)
I am interested too. Maybe even a more powerful or capable one for a larger motor build! (not to be a thread jacker) Thanks
Old Jun 26, 2005 | 07:41 PM
raylude's Avatar
Default Re: need to know what oil pump i can use (maxvtec7500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxvtec7500 &raquo;</TD></TR><TR><TD CLASS="quote">I am interested too. Maybe even a more powerful or capable one for a larger motor build! (not to be a thread jacker) Thanks</TD></TR></TABLE>
i dont mind i whould like to know that too
Old Jun 27, 2005 | 07:46 PM
raylude's Avatar
dang nobody knows? well i can get a new one from honda for 160 i just found out i get a pretty good discount with them at my job
Old Jun 27, 2005 | 08:15 PM
95ONE's Avatar
Pro Drive. $200. Beefier. Stronger. I'm fairly sure they all interchange. Not 100% But close.
Old Jun 28, 2005 | 07:08 AM
raylude's Avatar
Default Re: need to know what oil pump i can use (nsxlr8)
i still heard bad things about prodrive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clone &raquo;</TD></TR><TR><TD CLASS="quote">Im doing this because people like prodrive make cheap oil pump gears that cost $300 and break easier than factory oil pump gears.</TD></TR></TABLE>
Old Jun 28, 2005 | 05:11 PM
PrettyLude's Avatar
you can't use the one from the h23 because it doesn't have the mounting points for the crank sensor
a factory oil pump should be fine for what you want to do
Old Jun 28, 2005 | 05:26 PM
raylude's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">you can't use the one from the h23 because it doesn't have the mounting points for the crank sensor
a factory oil pump should be fine for what you want to do</TD></TR></TABLE>
thank you thats the kind off info i was lookin for i found theis part numbers at majestic honda but couldnt see why it was so different guess i got to get one for a 5th gen but why is the 96 vtec pump close to the 5th gen pump in the number?
majestic honda part #'s on oil pumps
5th gen #31474
1996 4th gen h22 and h23 # 31472 and #31473
4th gen h22 #109834
4th gen h23 #109834
4th gen f22 #93743 and #93744
Old Jun 28, 2005 | 05:31 PM
Sam1am26's Avatar
Default Re: (raylude)
Probably because the 96 is OBD2 and would have the crank angle sensor on the pump as well...
Old Jun 28, 2005 | 05:33 PM
raylude's Avatar
Default Re: (Sam1am26)
does that mean it could work on my 5th gen?
Old Jun 28, 2005 | 05:49 PM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude &raquo;</TD></TR><TR><TD CLASS="quote">does that mean it could work on my 5th gen?</TD></TR></TABLE>
Well, I don't know for sure but if the only difference is the spots to mount the crank sensor I don't see why not... Is it cheaper than a 5th gen oil pump?
Old Jun 28, 2005 | 06:04 PM
JonGP4's Avatar
when we rebuilt our race h22a4 block, we bought the oil pump gear inside that entire casing.. i believe it was 70-80 bucks.. been making 600whp with no problems on the oil pump
Old Jun 28, 2005 | 09:40 PM
raylude's Avatar
Default Re: (JonGP4)
oh well i dont have that kind of problem from my oil pump it works fine the problem is a mounting hole on the casing is striped and leaks so i just need the whole thing and just want to know if i can use one from another h motor cuz it might be cheaper i just dont wanna check unless i can use it the 5th gen one will cost me 160 with my disscount at honda witch is funny cuz an aftermarket one from my job is like 250
Old Jun 29, 2005 | 11:37 AM
raylude's Avatar
bump anyone?
Old Jun 30, 2005 | 04:37 PM
raylude's Avatar
realy? has no one ever tried this help a poor brother out im tryin to save as much money as i can i got body work to finish as well.
and you know what im goin to do if yall cant help me
92integraVTECgsr
Jan 28, 2007 08:25 PM
johng
Mar 30, 2006 06:53 AM
StolenTeg
Oct 3, 2004 06:50 PM
kerby116
Mar 1, 2004 03:34 AM
