+++ <<<< a BAJILLION parts f/s >>>> +++
Everything is located in 91730 so cal 10/15 fwy area - everything can be shipped and nothing will be parted - prices are pretty close to firm. I have a quadrillion vouches so just ask.
Will trade for
spoon black shifto ****
F/S
1. 2 pairs of d series EG axles 35 ea. 20 for the driver side wrapped - needs rebuild
2. 92-95 civic coupe/sedan exhaust complete - 60
3. sand blasted b20/b18 valve cover super clean (drying in pic) - 50 <
also have a stripped b16 valve cover super clean - 60 >
4. neuspeed chromoly rear lower tie bar for del sol civic teg ect, test fitted only - 60
5. 60mm t/b will fit 92+ d series (8mm bigger than stock) or 88+ b series - can be ported to 64mm with a taper - 60
6. b16a2 IM good condition - great for home made ITB's ect - 60
7. stock eg headlights, no missing parts ect. - 40
8. 60mm t/b spacer reduces intake temperature and improves velocity, never used - 30
10. D series eg shift linkage excellent condition, with shifter - 60
11. B series stock header with heat sheilds, no dents ect and donut gasket - 60
12. D series stock header with heat sheilds, no dents ect and donut gasket - 50
13. Gutted OEM stainles cat - 30
14. brand new stainless cat used for less than 30 minutes to pass smog - 90
15. stock EG air box and arm modded to fit b series t/b - 20
16. Brand new h4 silverstars - used for 45 minutes after my hids went out on the way home - 30
17. VehicleSpeedSensor in excellent condition - 40
18. Trans reverse switch - 20
19. D series eg throttle cable - 15
EK coupe/hatch spoon style mirrors excellent condtion - 60
Esses / QR quick release hub for sparco/momo ect hubs in stealth black excellent condtion - 80
front seats in limited edition grey cloth - 200 for both no seperating obo
Integra GSR rear seat cusion and side bolsters - 60 bottom fits eg hatches going for gsr interior perfectly
52 mm D series TB's - 35 ea 56mm zc tb will fit 88-91 si IM's - 40 56mm y8 tb - 40
ERS springs, 250 f 150 r great for daily drivers ect - best springs on the market (for coilovers only ) never used 160
62mm ported y8 manifold with injectors ect - 90
62mm ported d16a/d15b intake manifolds fuel rails, injectors ect - 60 ea.
lockhart phillips true carbon fiber sport bike mirrors with 2 post mounting brackets included - never used - 80
crunch 4 channel 400 watt amp in excellent condition with gold rca's ect - 120
honda racing team sweater and pressed t shirt never used 30 / 15
1 BMW F1 shirt in XL blue, prewashed it never used 20
2 EG stock steering wheel in black with unused airbag and srs ring 90 ea. One black and one grey
Versus Carbon fiber del sol hood - Exactly the same design as Fiber Images will fit k20 swaps ect. - 320
del sol mirrors excellent cond - 70
Kenwood 300 watt sub in custom ported box in great cond 90
4 240 cc Saturated injectors - 40
SPC front ball joints for camber correction, barely used - 80
Modified by stormy at 6:59 PM 6/27/2005
Modified by stormy at 10:16 AM 7/3/2005
Modified by stormy at 5:17 PM 7/5/2005
Modified by stormy at 8:27 PM 8/1/2005
Will trade for
F/S
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stormy »</TD></TR><TR><TD CLASS="quote">woot! there it is</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stormy »</TD></TR><TR><TD CLASS="quote">up like captain one eye </TD></TR></TABLE>
how did he become one eye?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA-Cutie »</TD></TR><TR><TD CLASS="quote">
would'nt you like to pinochiknow!
</TD></TR></TABLE>would'nt you like to pinochiknow!
ev94eg
May 14, 2012 09:50 PM
