13/16 and 15/16 master cylinder use same resevoir?
Old Jun 26, 2005 | 02:31 PM
mdmitch2's Avatar
Default 13/16 and 15/16 master cylinder use same resevoir?
I'm doing some work on my brakes (89 CRX si), and was going to get a new 15/16 master cylinder from a 91 civic ex at autozone. Will the resevoir from my old 13/16 MC fit the new one? I couldn't find the answer searching the archives...
Thanks in advance!
Old Jun 26, 2005 | 04:18 PM
onePOINTsix's Avatar
Default Re: 13/16 and 15/16 master cylinder use same resevoir? (mdmitch2)
I put my 15/16" on yesterday and used a Teg resevoir but the civic one looked like the bottem was the same
Old Jun 26, 2005 | 04:57 PM
CRX Toad's Avatar
Default Re: 13/16 and 15/16 master cylinder use same resevoir? (onePOINTsix)
Your better off to use the Integra reservoir cause you don't want to be going a around a turn and suck all the fluid out and put air into the lines. You need the proper reservoir.
Old Jun 26, 2005 | 05:33 PM
Default Re: 13/16 and 15/16 master cylinder use same resevoir? (CRX Toad)
good advice, the Teg resevoir is alot bigger then the civic one but i dont think it could suck all that fluid out
edit: pic of the 15/16" w/ teg resevoir
Old Jun 26, 2005 | 05:35 PM
8Si8's Avatar
I just got done with mine a few hours Ago and it worked just fine
crexer's Avatar
yes your old reservoir will work perfectly
Old Jun 26, 2005 | 06:13 PM
Garrett's Avatar
Default Re: 13/16 and 15/16 master cylinder use same resevoir? (crexer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">yes your old reservoir will work perfectly</TD></TR></TABLE>
it could work
but the 15/16 is a lot bigger
Old Jun 26, 2005 | 06:16 PM
FkingSUV's Avatar
Default Re: 13/16 and 15/16 master cylinder use same resevoir? (Garrett)
yeah your system will never move that much fluid at once
Old Jun 26, 2005 | 07:06 PM
JK_Motorsports's Avatar
Does anyone have problems running the larger &lt;aster. i had a 88 Prelude Master on mine(15/16) and I had a really floating pedal. Upon hard slamming it felt great! But while waiting at a stop light or in a drive through the pedal would slowly drop to the floor. I've tried 2 different ones and got the same results. I have since gone back to my DX Master and all seams well, but I love the shorter pedal travel of a larger master.
Old Jun 26, 2005 | 08:14 PM
Rob.'s Avatar
What's the benefit if a larger master cylinder ? It just moves more fluid ?
Old Jun 27, 2005 | 05:18 AM
mdmitch2's Avatar
Default Re: 13/16 and 15/16 master cylinder use same resevoir? (Rob.)
Thanks for the info guys. I couldn't get my hands on a larger resevoir on a sunday, so for now I'm just going to use the old one. I'll pick up a larger one next trip to the junkyard.
Did all of the cars that came with the 15/16 MC have a larger resevoir? In other words, is it the same resevoir on the 89 accord, 88 prelude, 91 civic ex, and integra?
Old Jun 27, 2005 | 05:39 AM
crx_88_si's Avatar
Default Re: 13/16 and 15/16 master cylinder use same resevoir? (bumblezc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bumblezc &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have problems running the larger &lt;aster. i had a 88 Prelude Master on mine(15/16) and I had a really floating pedal. Upon hard slamming it felt great! But while waiting at a stop light or in a drive through the pedal would slowly drop to the floor. I've tried 2 different ones and got the same results. I have since gone back to my DX Master and all seams well, but I love the shorter pedal travel of a larger master.</TD></TR></TABLE>
That could be an indication of a leaking brake line / cylinder (rear drums?) or a leaking caliper piston.
Old Jun 27, 2005 | 05:50 AM
fujii13's Avatar
you might want to think about replacing the brake booster in these instances, too.
Old Jun 27, 2005 | 06:46 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mdmitch2 &raquo;</TD></TR><TR><TD CLASS="quote">Did all of the cars that came with the 15/16 MC have a larger resevoir? In other words, is it the same resevoir on the 89 accord, 88 prelude, 91 civic ex, and integra?</TD></TR></TABLE>
Yes.
Old Jun 27, 2005 | 08:37 AM
Default Re: 13/16 and 15/16 master cylinder use same resevoir? (crx_88_si)
Nope, because with the DX Cylinder works fine with no leaking.
Old Jun 27, 2005 | 08:43 AM
GSRCRXsi's Avatar
were you using used master cylinders?
i had the same problem and the master cylinder was bad. i replaced it with one from autozone and all is fine now. no pedal sinking now
skill178
16
Oct 10, 2011 06:18 AM
pinoyboy204
Oct 17, 2007 02:10 PM
CroSi
Jan 29, 2007 08:18 PM
dat_flip
Jun 23, 2004 03:58 PM
CXHatchback
Jul 17, 2003 09:57 PM
