will this radiator fit in my 93 ex?
will this radiator fit in my 93 civic EX (d16z6)
JDM EG 92-95 Civic SIR radiator with fan assembly.
from the website:
http://www.passwordjdm.com/pro...D=364
they dont have a picture and details or anything, but it looks like a good price and im in need of a new radiator badly (california heat!!!)
from the website:
it is most likely the dual core radiator.
i'm assuming it is used.you'd be better off to buy a new one-they can be had on Ebay for around the same price.
the fan assembly is no different than yours.
Chris
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">it is most likely the dual core radiator.
Chris</TD></TR></TABLE>
thanks man, but i mean "size wise" will it fit in that small slot my stock radiator fits in....seems like a good price to me, at honda they charge something in 150-200$
autozone is also above 100$
i was just wondering if anyone knew if the dimensions were similar enough to Pop in my engine bay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay-Dee-Em »</TD></TR><TR><TD CLASS="quote">
i was just wondering if anyone knew if the dimensions were similar enough to Pop in my engine bay</TD></TR></TABLE>
yes,it will fit right in,no problem.
Chris
Chris
nope it will not fit unless modyfied which is risky.
Pipe diameter is different as i bought the wrong rad for my b16 by accident which was for d16z6 and my pipe diameter was too big.
sam
sam
The radiator hoses will still strech to fit over the larger pipe. The main problem your going to run into is your automatic transmission. Auto trannies require a trans cooler. The automatic cars have one built into the radiator. This means their are transmission fluid lines that hook up to your radiator from your transmission. If you get a manual cars radiator, it won't have those fitting, and you will be requried to run a separate transmission cooler. I don't think you want to be doing that since you sound like a frugal guy. Just take a look on ebay for "92 civic radiator", and you will find aluminum ones like here for under $50 shipped that fit automatic cars for sure...
