where cani find a good b18 or b16 swap for my 91 hf crx
Old Jun 26, 2005 | 01:19 AM
1_QWIK_HF_CRX's Avatar
Default where cani find a good b18 or b16 swap for my 91 hf crx
everything brakes and spindles and everthing
Old Jun 26, 2005 | 04:18 AM
Kidnkorner's Avatar
Default Re: where cani find a good b18 or b16 swap for my 91 hf crx (1_QWIK_HF_CRX)
You dont need brakes or spindles to swap a B series motor into you CRX.
for the SWAP
HMotorsOnline.com This Vendor will discount the purchase of new HASport mounts and new HASport axles with the purchase of a Swap
Total JDM
JDMshit.com
for the Mount kit with a cable operated transmission. For a Mount Kit with a hydraulic operated transmission, and axles
Modified by Huggy Bear at 8:33 AM 6/26/2005
Old Jun 28, 2005 | 01:42 PM
Default Re: where cani find a good b18 or b16 swap for my 91 hf crx (Huggy Bear)
acctually i do need spindles and brakes
Old Jun 28, 2005 | 01:45 PM
EP3_05's Avatar
Try http://www.importautosalvage.com
They run a salvage yard so they could probably get you a package deal with the swap, mounts, axles, brakes, and spindles.
Old Jun 28, 2005 | 01:46 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_QWIK_HF_CRX &raquo;</TD></TR><TR><TD CLASS="quote">acctually i do need spindles and brakes</TD></TR></TABLE>
Yes you do since you have an HF. Go to http://www.hmotorsonline.com and I might as well get the Teg brakes if I were you.
Old Jun 29, 2005 | 03:30 AM
Kidnkorner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Huggy Bear &raquo;</TD></TR><TR><TD CLASS="quote">You dont need brakes or spindles to swap a B series motor into your CRX.</TD></TR></TABLE>
w0w i'm no stranger to the honda game, but misinformation
Huggy Bear y0!
Old Jun 29, 2005 | 04:34 AM
Autoworks's Avatar
Haven't you asked this same question about 5 times, just rephrased?
hmotorsonline is the place to go, I've bought 5 motors from him, always fast service, always got it right.
Just buy the full swap, then source some DA hubs/rotors/calipers, a shift linkage, Hasport harness, motor mounts and your pretty much set.
audiopipematt88
Nov 13, 2008 06:44 PM
mrtrex
Aug 23, 2006 08:17 AM
Mugen2324
Apr 10, 2006 07:34 AM
97EXCivicCP
Feb 2, 2006 06:40 PM
kleanlscivic
11
Mar 11, 2005 03:32 AM
