Intake Manifold Gasket 4 Pieces!
Old Jun 25, 2005 | 10:01 PM
cpforyou's Avatar
Default Intake Manifold Gasket 4 Pieces!
So I've seen the normal intake manifold gaskets, the one between the IM and the Head. But what about this? You guys think this will do any better?
EDIT:
I found it here:
http://cgi.ebay.com/ws/eBayISA...=WDVW
Modified by cpforyou at 12:49 PM 6/26/2005
Old Jun 26, 2005 | 12:26 AM
TimeRacer's Avatar
Default Re: Intake Manifold Gasket 4 Pieces! (cpforyou)
No, as the whole point of the gaskets is just to take the metal to metal contact away from the heat source, which is the engine. Once you do that, all the extra gaskets that you see there are surpurfluous unless you don't do the coolant bypass, but then you'd need the IACV gasket which isn't here. I don't see any point to the butterfly gaskes though, that IF these are all made of nylon.
Old Jun 26, 2005 | 05:45 AM
pheurton-skeurto's Avatar
yeah, same response, the hondata gasket (or similar) is designed to isolate the IM from the head to lower intake temps. out of curiosity though who sells this...
Old Jun 26, 2005 | 10:50 AM
Hawkze_2.3's Avatar
I've thought about this a few times. Even if the heat difference wasn't much, these are still lifetime gaskets. I wouldn't mind not having to worry about oil-soaked gaskets or changing them....
Where did you find these???
Old Jun 26, 2005 | 11:50 AM
cpforyou's Avatar
Default Re: Intake Manifold Gasket 4 Pieces! (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">I've thought about this a few times. Even if the heat difference wasn't much, these are still lifetime gaskets. I wouldn't mind not having to worry about oil-soaked gaskets or changing them....
Where did you find these???</TD></TR></TABLE>
I found it on eBay. The reason I thought about it is because I have a Hondata Intake Manifold Gasket. Although my manifold runs cooler, it's still fairly warm. With multiple gaskets, make the temperature could be colder by the time you touch the throttle body. (of course with the coolant bypass).
Old Jun 26, 2005 | 02:01 PM
TimeRacer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpforyou &raquo;</TD></TR><TR><TD CLASS="quote">I found it on eBay. The reason I thought about it is because I have a Hondata Intake Manifold Gasket. Although my manifold runs cooler, it's still fairly warm. With multiple gaskets, make the temperature could be colder by the time you touch the throttle body. (of course with the coolant bypass).</TD></TR></TABLE>
Though have you determined that the heat from this is from the engine or just allowing the heat in the engine bay to rise when you stop? A lot of that heat you'll find will be gone after driving on the freeway, get off and immiedately find a place to park and pop the hood and feel the IM. It should be relatively close to amblient.
Old Jun 26, 2005 | 02:23 PM
high_revs's Avatar
yeah i'd have to agree. it should almost be cold at the tb
M2S~Jaime
Dec 14, 2006 03:04 PM
Shizznaz
Sep 2, 2005 08:07 AM
dualknuttz1
Jan 23, 2004 08:37 PM
