Im so torn between these two swaps....
Old Jun 25, 2005 | 09:02 PM
EG_Civic_Si's Avatar
Default Im so torn between these two swaps....
I need some opinions. I know i know...Its what I want to do, I shouldn't rely on other people opinions....but I honestly do not know which one.
Going into a EG6 Hatchcrap.
I thank you all in advance. Flame on if you'd like....i can take it.
__________________________________________________ __________________
[B]This is from http://www.speeddohctors.com[/B]
B-Series Specialists...
Monthly Special:
LS-VTEC with JDM P30 Pistons, GSR Head, B16 Tranny, ITR Cams and 0 miles - $4100 installed!
This one is from Jspecautosports.com
$3849
Specifications
DOHC VTEC 4 Cyl. 16 Val.
• Year: 1992-1995
• HP: 190hp@7600 Aprox.
• Torque: 136 lb-ft@7300 Aprox.
• Redline: 8200 rpm
• Diplacement: 1595cc
• Compression Ratio: 10.4:1
• Transmission Type: Hydraulic
List Of Parts Included
• Complete Motor
- Block
- Intake Manifold
- Complete Head
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Alternator
- Starter
- Ignition Wires
- A/C Compressor
- Power Steering Pump
- Headers
• OBD1 ECU (Computer)
• 5-Speed LSD(Limited Slip Differential) FWD Hydraulic Transmission
• Intermediate shaft
• Engine Mounts
• YONAKA MOTORSPORTS Drive Shafts
• YONAKA MOTORSPORTS 92-00 Civic Race Radiator
• YONAKA MOTORSPORTS Ultra Lightweight Flywheel
• Street Imports JDM 4-1 Headers
• AVID Racing Shift Linkage
• YONAKA MOTORSPORTS 2.25 Inch Cat-Back Exhaust
Old Jun 25, 2005 | 09:09 PM
MiMiK's Avatar
how could the displacement be 1595cc if it's using a 1.8 ls block???
and that 10.4:1 compression seems a tad low.. those look like specs from a stock b16(except for the hp and tq numbers).
Old Jun 25, 2005 | 09:15 PM
Default Re: (MiMiK)
they are 2 different swaps listed.
the 2nd one is a B16
Old Jun 25, 2005 | 09:17 PM
MiMiK's Avatar
Default Re: (EG_Civic_GSR)
whoops...just read it carefully..
i wouldn't choose either.
Old Jun 25, 2005 | 09:19 PM
Default Re: (MiMiK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiMiK &raquo;</TD></TR><TR><TD CLASS="quote">whoops...just read it carefully..</TD></TR></TABLE>
So...what do you think?
Old Jun 25, 2005 | 09:29 PM
ZedEx's Avatar
That first one sounds awfully tempting... But $4,100... Nah.
What kind of set-up do you have now?
Old Jun 25, 2005 | 09:32 PM
Stoich EG2's Avatar
Default Re: (ZedEx)
i'd choose the first one because it's COOL! Are you planning on installing yourself?
ever wonder why you're at 91%?
Old Jun 25, 2005 | 09:33 PM
The_Todd's Avatar
Farts in the shower
Default Re: Im so torn between these two swaps.... (EG_Civic_GSR)
For 4100...hell no.
What is your current setup?
Old Jun 25, 2005 | 09:35 PM
HATCHingMN's Avatar
4 grands for a B16...
Hell NO
Old Jun 25, 2005 | 09:40 PM
Default Re: Im so torn between these two swaps.... (HATCHingMN)
I know why I am at 91%....dont worry about that.
Currently I have a Stock CX hatchback.
Old Jun 25, 2005 | 09:42 PM
HATCHingMN's Avatar
EG_Civic_GSR
you can find some Integra type R swap in your area for the same price
Old Jun 25, 2005 | 09:52 PM
The_Todd's Avatar
Farts in the shower
JDM **** has a jdm b16 full swap for 2250. http://www.jdmshit.com/parts/engines/index.html
h22 for 2400
Hell even a b18c for 3200.
Old Jun 26, 2005 | 12:43 AM
90sedan's Avatar
$4100, is way to much man. You can find way cheaper than that.
Old Jun 26, 2005 | 07:10 AM
Juggernaut 2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_Civic_GSR &raquo;</TD></TR><TR><TD CLASS="quote">
Specifications
• Year: 1992-1995
• Redline: 8200 rpm
• Transmission Type: Hydraulic</TD></TR></TABLE>
Which B16 is making 190?
Modified by Juggernaut 2 at 8:42 AM 6/26/2005
Old Jun 26, 2005 | 07:19 AM
moto1320's Avatar
Default Re: Im so torn between these two swaps.... (Juggernaut 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Juggernaut 2 &raquo;</TD></TR><TR><TD CLASS="quote">
Which B16 is making 190?</TD></TR></TABLE>
lol, beat me to it.
At any rate, I wouldn't go with either.
Old Jun 26, 2005 | 07:21 AM
skunkintegra's Avatar
Default Re: Im so torn between these two swaps.... (.ken)
don't get either of them!
get this -&gt;http://www.hmotorsonline.com/s...30010
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken &raquo;</TD></TR><TR><TD CLASS="quote">JDM **** has a jdm b16 full swap for 2250. http://www.jdmshit.com/parts/engines/index.html
h22 for 2400
Hell even a b18c for 3200.</TD></TR></TABLE>
werd
Old Jun 26, 2005 | 11:36 AM
Professor15's Avatar
For the money you are about to spend, either peice together your own Ls-vtec which will make more power depending on the parts you chose with the same money. Or do a h22...
Old Jun 26, 2005 | 12:03 PM
Used2beAb16's Avatar
first of all the second swap is a b16 and u shouldnt even bother. The first swap is a decent setup since everything is brand new. thats why the price is as such.
I guess if you were to build everything new it would cost that much but u can get a setup like that for cheaper, just not 0 miles.
Old Jun 26, 2005 | 12:18 PM
philafelman's Avatar
Modified by Juggernaut 2 at 8:42 AM 6/26/2005</TD></TR></TABLE>
or better yet, 136lb/ft torque??
BIG T
Apr 7, 2014 05:40 PM
cockerkid008
Mid-Atlantic (Sales)
Jun 15, 2009 05:57 PM
Spoon84
Apr 10, 2009 10:18 AM
iKhmaiFoSho
Northeast (Sales)
Mar 28, 2008 02:09 PM
lucky one
Feb 19, 2004 09:27 PM
