spray painting my car
if i spray paint my car piece by piece when im done can i use a spray gun for clearing the whole car?? if so will it last and not fade the paint
what i need to know is if i need a fresh coat then lay the clear like 45min. later or just when ever if i wet sand before the clear and will the clear crack or peal early like in the first year or so
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4ghatch »</TD></TR><TR><TD CLASS="quote">if i spray paint my car piece by piece when im done can i use a spray gun for clearing the whole car?? if so will it last and not fade the paint </TD></TR></TABLE>
If you have access to a spray gun for clearing why dont you use ti spray the base coat too? I don't get it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calxtreme »</TD></TR><TR><TD CLASS="quote">you have to sand before you clear so the paint will be even and to stick.</TD></TR></TABLE>
i am but i but will it stick fine after wet sand or not?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackwagon »</TD></TR><TR><TD CLASS="quote">If you have access to a spray gun for clearing why dont you use ti spray the base coat too? I don't get it?
simple spray paint and primer cost me $less than $100 and primer, paint and whatever chemicals i need to mix in with the paint was going to be $394 (for the Omni crap) Besides the hood is done with paint just needs clear coat it is totaly even!
</TD></TR></TABLE>simple spray paint and primer cost me $less than $100 and primer, paint and whatever chemicals i need to mix in with the paint was going to be $394 (for the Omni crap) Besides the hood is done with paint just needs clear coat it is totaly even!
