car bogging down any help
97 honda civic single over head vtec with a greddy turbo kit problem is car is bogging down while driveing please help
a friend said i might need to reprogram ecu another one says to get bigger fuel injecters what should i do thanks have a nice day
did the car just start doing this,or has it always ran bad?
check your ignition timing,do a tune-up,check for ECU codes,do a compression test.......
we need more info.does it bog only in boost?does it bog at all RPMs?
Chris
Chris
it just started doing it if u pull out at a stop it acts like its starving .then it just takes off im not to big of a wrench guy im stumped.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_Del Sol »</TD></TR><TR><TD CLASS="quote">bring it to a shop to get fixed duhh </TD></TR></TABLE>
that wasnt needed
I had a similiar problem, it turned out to be my spark wires.
Check, wires, plugs, distrubitor, etc.
Good luck.
that wasnt needed
.I had a similiar problem, it turned out to be my spark wires.
Good luck.
ill try that thank u i just started getting into the import seen i use to do mini trucks but i got sick of it and a friend told me about this site i i just wanted to look around and see if i can make more of my ride
search on here..there are 100's of good threads about this so you can get an idea of what to look for....start with timing,plugs,wires etc
Modified by 94_Del Sol at 7:06 AM 6/26/2005
Marble
Feb 10, 2006 05:18 AM
91hob20hb
18
Jan 28, 2004 05:28 AM
CR-V
49
Nov 5, 2003 10:52 PM
