size of fittings and hydraulic line for clutch line.
I am putting an Accord 5 speed in my 97 lude and am considering doing a custom braided line for the clutch. I want to build one to go strait from the master cylinder to the slave cylinder. I am doing this to avoid messing around with the accord hard line.
does anyone know the type and size of the fittins and line I will need?
thanks a bunch guys
scotty
thanks a bunch guys
scotty
You should be able to just reuse your hardline from the lude. The rubber line that goes from the top of the tranny to the slave cylinder should be the only one to be replaced, if you want that one I have a steel braided line already made up for that purpose. I'll sell it to you for $25 plus shipping. If you were to make the whole line out of steel braided it would cost you a good penny, because that is one long line.
I have the auto.... I am converting to manual. I want to do the whole line in braided... should be able to do it for around $30-$35 if I put it togethere myself.
B18EG6
Apr 9, 2003 05:57 AM
