Suspension & Brakes Theory, alignment, spring rates....
rear sway bar bushings
Old Jun 25, 2005 | 03:00 PM
blackie's Avatar
Default rear sway bar bushings
i have a 99 civic coupe. i just purchased the 22mm rear type r sway bar. i was wonderinf if any 22mm bushing and bracket will work or does it have to be specifically for the civic? any suggestions as to where i can get some that would fit?
Old Jun 25, 2005 | 04:46 PM
blackie's Avatar
bump!
Old Jun 27, 2005 | 07:23 AM
blackie's Avatar
anyone? bump
Old Jun 27, 2005 | 08:20 AM
DC4_MADMAN's Avatar
ITR(USDM) bushings and brackets
Old Jun 27, 2005 | 01:14 PM
blackie's Avatar
Default Re: (4door_demon)
those would mount str on without a problem?
Old Jun 27, 2005 | 01:30 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (blackie)
The 22mm rear bar tear your rear subframe apart. Your going to need to reinforce it unless you don't mind replacing the subframe.
Look into the A-Spec-Racing (or ASR as they are commonly known) subframe brace or comptech's rear sway/tie bar...
Run Away
12
Aug 28, 2011 02:55 PM
zccivicex
May 4, 2009 04:40 PM
miraclehonda
Sep 8, 2008 04:14 AM
GreenBean
Feb 26, 2004 01:01 PM
RICHJ
Dec 18, 2002 01:49 AM
