Need Help: white smoke out of exhaust
i have a jdm gsr motor and after letting my friend drive my del sol i have white smoke coming out of the exhaust now. he said he was reving up to 8000 rpm which i told him not too. does anybody have an idea of what is wrong?
only mods i have is ported head, exhaust, and mugen chipped ecu.
thick white smoke? **** man, dont drive it, my car today is sitting in my garage dead now cuz of that, its the coolent being burned cuz ur head gasket if cracked or warped, be sure to check your engine temp, and dont over heat anymore.....
i changed my oil on my bad motor and all the coolent had mixed with the oil, out came 6-7 quarts instead of 4 from my little civic
goodluck to you
goodluck to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH2rbg93 »</TD></TR><TR><TD CLASS="quote">Your burning oil, that is usually the cause for white smoke. Rings may be bad or like allan said your headgasket</TD></TR></TABLE>
white smoke is coolant
blue smoke is oil
white smoke could happen from a blown headgasket (most likely), cracked head, cracked block, or twisted (warped) head
but more than likely its the headgasket
do a compression test or a leakdown test
blue smoke is oil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoursupahero09 »</TD></TR><TR><TD CLASS="quote">how much does is usually costs to change the head gasket? and recommended shops in in so cal orange county to be exact.</TD></TR></TABLE>
thats easy to find out, pick up the phone and start calling places... cause we dont know...
the honda dealer in diamond bar said theyll change the headgasket for $800
thats a major ripoff...
its cheapeast if you do it yourself and its not that hard if you know what youre doing
best way to find cheap places is just call around...
Youll never prove it was him but if hes a good friend hed help you pay for it. Driving it once like that shouldent damage a head gasket, Im sure you've done that a few times too.
Im Luserkid on here, he does work like that and hes in your area I THINK? ask him hes the guy to talk to!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allanonjj »</TD></TR><TR><TD CLASS="quote">sounds like a head gasket,..... or maybe your flux capacitor has gone bad</TD></TR></TABLE>
LMAO!!! baaaahahahah funny ****
headgasket most likely buddy
If you need someone cheap to do it get ahold of me, heres different ways of getting in contact. https://honda-tech.com/zerouser...19459
If it smokes all the time, idle and worse when you get on it then its more then likely headgasket. What you could do is check your oil and check your coolant. If the coolant looks milkie and looks like oil is in there then its headgasket, same with oil.
TheFamilySign
35
Mar 3, 2014 12:12 PM
Redprelude98
Nov 25, 2008 10:42 AM
JunkyardAccord
Nov 18, 2008 10:11 AM
3rd gear vt3kc pullz hard
Jan 25, 2004 03:36 PM
i did mine myself in a few hours, its easy, deinitely not worth 800 bux
