engine rebuild...
anybody no the basics to an engine rebuild. (this is a b18b by the way) so far i have read:
-rods
-pistons
-vavle springs
-camshafts
-cam sprockets
anything else i need for an engine restoration? everything in the block and the head. excluding transmission, dizzy, etc... i appreciate it thanks.
-rods
-pistons
-vavle springs
-camshafts
-cam sprockets
unless the engine is damaged you can reuse everything u listed, i would just get your crank turned and get new piston rings and new bearings and get your block honed. new gaskets and you should be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egvtec »</TD></TR><TR><TD CLASS="quote">unless the engine is damaged you can reuse everything u listed, i would just get your crank turned and get new piston rings and new bearings and get your block honed. new gaskets and you should be fine.</TD></TR></TABLE>
Correct,.....as usual
