89 Crx si swapped OBD1 dohc ZC, Clueless of wiring harness and distributor to use...
Old Jun 25, 2005 | 12:18 PM
Glock17's Avatar
Default 89 Crx si swapped OBD1 dohc ZC, Clueless of wiring harness and distributor to use...
I recentlly swapped in a OB1 dohc ZC motor(grey plug).I'm using the Si ecu for now. I'm trying to figure out what route to take with the engine harness and distributor. If I go with the si harness and OBD0 (89 integ)distributor the crank angle position sensor is an issue, because on the OBD1 motor it doesn't have a plug for the RYWIRE distributor adapter plug I'm using. My other option was to use a JKOBD adapter harness( OBD0-OBD1) and use a OBD1 ecu. I need to know whats the easiest way of doing it and the most cost effective.
(z6ef)187
May 31, 2011 05:49 PM
hudson13
Dec 10, 2010 04:54 AM
moskaEF9
Jun 12, 2009 05:43 AM
juanb
Oct 27, 2004 07:47 PM
