Fuel Pump Not Engaging
Old Jun 25, 2005 | 12:15 PM
Schrader's Avatar
Default Fuel Pump Not Engaging
Okay guys, I got the B18C1 all wired up. Now it turns over, But the there fuel pump does not engage. Any suggestions?
Old Jun 25, 2005 | 12:18 PM
nota-eg's Avatar
Default Re: Fuel Pump Not Engaging (Schrader)
Did you replace the fuel pump? Or is it the one you had before the swap?
Old Jun 25, 2005 | 12:28 PM
Schrader's Avatar
Its the orignal Fuel pump that was in the car when I drove it in.
Old Jun 25, 2005 | 12:33 PM
nota-eg's Avatar
Default Re: (Schrader)
Check the ground and lead to the fuel pump. Mabe use a test light to make sure its getting power and has a good ground.
Old Jun 25, 2005 | 01:03 PM
beaterdriver's Avatar
check the ecu fuse under the hood, mine blew and the fuel pump would not come on
EJ8CIVIC
Jul 5, 2015 12:07 PM
mr devious illusions
Mar 24, 2007 11:19 AM
prelude994e
Sep 13, 2004 11:23 AM
VspecSiR
May 17, 2004 04:37 AM
85mm LsVTEC
Dec 22, 2003 10:19 AM
