How do you change 95 Accord Tranny Fliud and how many qarts??????
Old Jun 25, 2005 | 11:31 AM
CR-Vision99's Avatar
Default How do you change 95 Accord Tranny Fliud and how many qarts??????
Somebody please help me!!!
Old Jun 25, 2005 | 03:43 PM
sj993's Avatar
Default Re: How do you change 95 Accord Tranny Fliud and how many qarts?????? (Vtec_Tommy)
For an automatic or manual? Either way it's pretty easy. There is a drain bolt on the side of the transmission. Take that off and the fluid will drain. Refill through the dipstick in the engine compartment. I believe the Auto's take around 3 quarts of ATF. Honda ATF is recommended.
Manual tranny's may be a bit more using some type of oil. I don't remember which weight.
Old Jun 25, 2005 | 04:10 PM
raceACCORDingly's Avatar
manual tranny you drain from the drain hole and fill from the filler hole until oil comes dripping out the filler hole which is around 2qts. ive changed with 10w-30 but now currently running pennzoil sychromesh.
Old Jun 25, 2005 | 04:12 PM
Default Re: (raceACCORDingly)
its a AUTO
Old Jun 25, 2005 | 04:13 PM
Default Re: How do you change 95 Accord Tranny Fliud and how many qarts?????? (sj993)
Thank you guys
KDoGx504
Oct 7, 2005 01:54 PM
Alibi86
Sep 9, 2005 06:02 AM
2KCivicDude
Jul 24, 2004 06:50 AM
Art Vandeleigh
Nov 18, 2002 05:55 AM
ModlesSI
Sep 17, 2002 01:22 AM
