some HELP please..accelerating problem
so heres the problem..whenever i drive for about 5 mins or whatnot ill start gasing it and it feels like the fuel is cutting off on me or something..like the tach goes crazy and i lose power then get it back and so on..i heard it could be the fuel filter but im not too sure..
Is the car stock, or have you done any work to it? Intake, exhaust, fuel pressure regulator, cam, cam gear, etc...? If you've added anything it may actually be starving your engine of fuel. A new fuel filter is always a good thing. You should be changing it about every other oil change. That will keep a lot of pressure off your fuel pump. Please post updates.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Proglow3 »</TD></TR><TR><TD CLASS="quote">Is the car stock, or have you done any work to it? Intake, exhaust, fuel pressure regulator, cam, cam gear, etc...? If you've added anything it may actually be starving your engine of fuel. A new fuel filter is always a good thing. You should be changing it about every other oil change. That will keep a lot of pressure off your fuel pump. Please post updates.</TD></TR></TABLE>
my car has intake and exhaust..thats it..i just did the swap (gsr) about 2 months ago...i just tried changing the fuel filter a few hours ago but the damn bolt on the bottom just wont budge...tried using pb blaster and still nothing, just starting to round the damn bolt which is no good...
skUnK2jdm
Jan 30, 2007 03:55 PM
3.point.2
Dec 16, 2006 01:12 PM
