Turbo an ITR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bLack_aRR »</TD></TR><TR><TD CLASS="quote">
1337 post bitches!!!! woot woot woot, hollaaaa yea. pshhhh goes my bov. my vtec goes wah WAH!</TD></TR></TABLE>
baha
baha
This might be a better place to ask that question, in general.
https://honda-tech.com/zeroforum?id=16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opie »</TD></TR><TR><TD CLASS="quote">Only f00ls turbo ITR's, right Ed?</TD></TR></TABLE>
Ummm ... This one will be coming back even stronger, end of this year or beginning of the next.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huskmusk »</TD></TR><TR><TD CLASS="quote">Recently purchased a Greddy bolt on turbo kit for my ITR motor. Will this kit be safe and reliable enough for a pretty much stock daily driver? IF not, what other mods should i do?</TD></TR></TABLE>
get good fuel managment like hondata/neptune and get it tuned, .. if you're keeping a/c use heatwrap. make sure to use the right spark plugs and change them every oil change, keep up regular maintnance. run oil like Xw40 or higher like Xw50 during summer, oh.. and have money for rebuild and/or beater.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opie »</TD></TR><TR><TD CLASS="quote">YES! I got dibs on 1st ride along
Just make sure it's warm out and Ed did not have any wine that day
<--- Has flashbacks from two thanksgivings ago
</TD></TR></TABLE>Just make sure it's warm out and Ed did not have any wine that day
As for that... Not my cup of tea, I was recently in a S/C R and it made me giggle like a little school girl. It was sooo smooth and linear I could not believe. But if you want it to be a DD, I'd would not go with turbo, It's just too tempting to boost more and more.
For nice power that prolly in the same price range as a Turbo kit, Try a K20.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">
For nice power that prolly in the same price range as a Turbo kit, Try a K20.</TD></TR></TABLE>
it is tempting....
hence the name boostjunkie.
it is tempting....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">get good fuel managment like hondata/neptune and get it tuned, .. if you're keeping a/c use heatwrap. make sure to use the right spark plugs and change them every oil change, keep up regular maintnance. run oil like Xw40 or higher like Xw50 during summer, oh.. and have money for rebuild and/or beater.</TD></TR></TABLE>
Smart advice.
Careful of boost creep on that kit.
It's fine for a daily driver, if you tune it properly. It seems like the rule of thumb is that anything less than 300 WHP is fine on the stock motor. You <U>will</U> break **** if you track it, mine lasted either 2 or 4 weekends depending on how you count. Comrpession in #3 started to suffer after two track weekends, was completely gone after 4.
-Chris, who started with that kit last year, welded on an external wastegate, cracked his ringlands, killed the turbo, replaced the turbo with a GT2871, cracked the exhaust manifold near the wastegate, is replacing the manifold with a Mini-me along with the turbo housing and a shiny new 3" downpipe... who swallowed a spider to catch a fly...
Smart advice.
Thanks for all the comments so far guys.. I have done some searching and have found that alot of people are putting lower compression pistons and aftermarket rods. Is that necessary, even though the greddy kit only puts out 7 psi. Is it worth the extra money for reliability and/or power?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huskmusk »</TD></TR><TR><TD CLASS="quote">Thanks for all the comments so far guys.. I have done some searching and have found that alot of people are putting lower compression pistons and aftermarket rods. Is that necessary, even though the greddy kit only puts out 7 psi. Is it worth the extra money for reliability and/or power?</TD></TR></TABLE>
you'll need a rebuil at some point.. so i'd get as much of stock motor as you can.. everything is a wear item including aftermarket internals, so get what you can out of stock and rebuild with forged pistons/rods..
Have decided to just rebuild it now because the car is burning oil at the moment..(either bad rings or vavle seals) . I am going with Arias forged pistons and Eagle H beam forged rods. What compression is optimal for my setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huskmusk »</TD></TR><TR><TD CLASS="quote">Have decided to just rebuild it now because the car is burning oil at the moment..(either bad rings or vavle seals) . I am going with Arias forged pistons and Eagle H beam forged rods. What compression is optimal for my setup? </TD></TR></TABLE>
9:1 is popular. You'll notice the power loss and turbo lag, but its safe and can support a lot of power on the stock block (I've heard of things as insane as 500 WHP on race gas, 400 seems more reasonable).
I would blow up your current motor first. It'll probably last a couple/few years if you're only driving on the street/strip and have it tuned well. Just keep adding oil, and add a catchcan for your PCV (Moroso one is simple enough).
