Everyones favorite argument. CAM TESTING. JUN Type 3 VS Skunk Type 2.
Old Feb 12, 2002 | 09:11 PM
ImportReview
Guest
Posts: n/a
Default Everyones favorite argument. CAM TESTING. JUN Type 3 VS Skunk Type 2.
I could have probably tuned the Skunk 2 Type 2's slightly closer.....with more exhuast cam gear tuning, but I ran out of time.
Look how the graphs are just like the SAME EXACT powerband. And looking and measuring the cams....they are damn close.
They both have exact VTEC points...and for fun, after I fully, fully tuned the JUN 3's, I dropped in the Skunk 2's and the tuning was almost exact. I spent hours tuning the Skunks and after hours, the difference in tuning was less than about a few percent...
For all those asking about Skunk Type 3's... I DID put them in...
I tune them tommorrow. I did one pass at exact same settings as JUN 3's and it made SAME peak, but 15 HP less in mid.
probably lean.
More coming.
Jeff
[Modified by ImportReview, 8:29 AM 2/13/2002]
Old Feb 12, 2002 | 09:20 PM
MackSpeed-616's Avatar
Default Re: Everyones favorite argument. CAM TESTING. JUN Type 3 VS Skunk Type 2. (ImportReview)
big surprise...
Old Feb 12, 2002 | 09:39 PM
rodimus's Avatar
maybe this is a dumb question...but what about the quality of each cam vs. each other
Old Feb 12, 2002 | 10:29 PM
WayneGro's Avatar
Default Re: Everyones favorite argument. CAM TESTING. JUN Type 3 VS Skunk Type 2. (EVOL)
Not saying this will happen. But remember Skunk2's first batch of their old cams were breaking left and right. They did however take care of their customers from what I heard, which is good. I just hope they put a lot of R&D time on these cams, you never know these days. They do have a very attractive price of them though.
Me personally I would stick with Jun3's. Proven time and time again.
Old Feb 13, 2002 | 12:28 AM
SEFIxCivic's Avatar
jeff,
what kind of springs do you need to run the skunk 2 cams? i'm not sure what kind i have, but they are the ones that are slimmer than stocks with a similiarly small titanium retainer. i think they're web kits. are you familiar with anything that sounds like that?
Old Feb 13, 2002 | 01:55 AM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default Re: Everyones favorite argument. CAM TESTING. JUN Type 3 VS Skunk Type 2. (WayneGro)
get it right please. the original skunk2 cams wore itself out and rocker arm pads out. bad, but totally different than "breaking left and right". for the record no skunk2 cams has ever broke into pieces, where there are cases of Toda, JUN, and Crower cams breaking.
Old Feb 13, 2002 | 02:52 AM
TypeR0149's Avatar
thanks for the test jeff, I knew that the specs were close, but never realized that they were this close
Old Feb 13, 2002 | 03:56 AM
MARC P's Avatar
Hey Jeff did you see a dip at around 6000 rpm's at first when you put the cams in and if so how did you get rid of it. My vtec is set at 5400 also and it climbs like that till 6000 then it dips down about 6 hp then climbs at that point i was wondering if that is because i have 2.25 exhaust and JDM 4 to 1. Also did you have it wanting to lean out right at vtec. Did you use a short ram intake on this motor and hondata.
Old Feb 13, 2002 | 04:07 AM
B18CXr's Avatar
What turboR dude said
Old Feb 13, 2002 | 04:34 AM
No-Gi's Avatar
Default Re: Everyones favorite argument. CAM TESTING. JUN Type 3 VS Skunk Type 2. (B18CXr)
I am definately gonna buy a set.
Old Feb 13, 2002 | 04:48 AM
TRuST's Avatar
Jeff,
What program are you using with the P72 ECU ? Also, what was there VTEC point ?
Old Feb 13, 2002 | 09:55 AM
AllMotorMadness's Avatar
Keep us updated Jeff...............
Old Feb 13, 2002 | 10:03 AM
Big Phat R's Avatar
Jeff - good info
Why were 310 cc/min injectors selected for this motor? Don't you want bigger ones in there?
Old Feb 13, 2002 | 10:06 AM
Blade's Avatar
New User
Default Re: Everyones favorite argument. CAM TESTING. JUN Type 3 VS Skunk Type 2. (AllMotorMaddness)
to skunk2! they copied the JUN 3's and called it their stage 2. So does that mean their stage 3 is a copy of Toda C cams? wow, great R&D work....I'm being sarcastic BTW.
[Modified by Blade, 11:07 AM 2/13/2002]
Old Feb 13, 2002 | 10:45 AM
Cheap Bastard's Avatar
New User
Default Re: Everyones favorite argument. CAM TESTING. JUN Type 3 VS Skunk Type 2. (Blade)
Damn is that true? Skunk2 is copying Jun cam profile. Can anyone confirm this?
I hope this is not the case, or I'll loose all respect for Skunk products. This doesn't mean that I won't buy their stuff, especially if it's alot cheaper.
CB
Old Feb 13, 2002 | 10:51 AM
chiangm's Avatar
anyone knows who is the actual manufacturer for skunk2 cams?
Old Feb 13, 2002 | 10:52 AM
Reid's Avatar
Global Moderator
So even Skunk2 admits that Toda's are better than JUN's.
Old Feb 13, 2002 | 11:05 AM
Black R's Avatar
25 Year Member
.....how about vs. toda c's and vs. skunk stage 3?
Old Feb 13, 2002 | 12:01 PM
Silock's Avatar
New User
Default Re: Everyones favorite argument. CAM TESTING. JUN Type 3 VS Skunk Type 2. (Reid)
Well, I would expect them to say that, especially if they copied them
Old Feb 13, 2002 | 12:15 PM
TRuST's Avatar
True, both cams have specs close to each other, but we still don't know there extact specs except for the lift and duration. We still have to consider the ramp rate that both these cams use. But even if they are the same there still cheaper than JUN and deliver the same amount power. I'll get them
[Modified by TRuST, 4:16 PM 2/13/2002]
Old Feb 13, 2002 | 03:16 PM
SEFIxCivic's Avatar
BFD... skunk2 aka group A has been doing this for a LONG time. looks at their strut bars, ect, exact copy of the spoon. I wouldn't be surprised if it came from the same factory in Taiwan. For years people out here in cali have known group A to be Japanese quality at Taiwan price. Now you don't think they actually got there by doing their own r & d right? people want things that work well and are cheap, and when they get that, they complain.
Old Feb 13, 2002 | 03:58 PM
StinkyTofu's Avatar
Default Re: Everyones favorite argument. CAM TESTING. JUN Type 3 VS Skunk Type 2. (SEFI8LOxCivic)
can these type 2's pass smog like the type 1's do?
Old Feb 13, 2002 | 05:17 PM
Malice's Avatar
New User
great info Jeff! I knew these cams would kick ***!
Old Feb 13, 2002 | 09:43 PM
Old Feb 14, 2002 | 12:02 AM
tjtruong's Avatar
New User
i Guess Skunk2's are best for the money
