Mounts for the B18c.
Check this, I am doing a b18c swap into my 90 CRX and the mounts I ordered were supposedly for any b-series motor, but the mounts don't fit nor do the holes align. What mounts should I look for and what are the second best after hasport?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Why settle for second best? </TD></TR></TABLE>
Just get hasport.
Just get hasport.
what mount doesn' fit? if you are swapping a b18c you need the timing cover block mount off a 90-93 teg (the part of the mount that bolts to the block and has the two studs that stick up)and you also need a rear tranny "elbow" off a 90-93 teg as well.
