shift light without a tach???
Old Jun 24, 2005 | 05:38 PM
heel-toe's Avatar
Default shift light without a tach???
is it possible to connect a shift light and have it go off at the correct redline rpm without a tach???
Old Jun 24, 2005 | 06:13 PM
Chris F's Avatar
Default Re: shift light without a tach??? (civicsrfasty0)
Are you in the right forum?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsrfasty0 &raquo;</TD></TR><TR><TD CLASS="quote">is it possible to connect a shift light and have it go off at the correct redline rpm without a tach???</TD></TR></TABLE>
Yes.
Old Jun 24, 2005 | 06:40 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
yes. autometer makes one. i have it in my car.
Old Jun 24, 2005 | 06:42 PM
heel-toe's Avatar
Default Re: shift light without a tach??? (Rodney)
in a civic cx which is tachless, where do you connect it to make it light up at 8500 for the type r engine???
Old Jun 24, 2005 | 07:04 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsrfasty0 &raquo;</TD></TR><TR><TD CLASS="quote">in a civic cx which is tachless, where do you connect it to make it light up at 8500 for the type r engine???</TD></TR></TABLE>
Why does it make a difference if you have a tach or not?
Have you tried asking in the Civic forum?
An autometer shift light install guide. Pretty simple.
http://www.egauges.com/pdf/AutoMeter/397f.pdf
Old Jun 24, 2005 | 07:05 PM
Kendall's Avatar
You connect it to the tach signal input wire. And regarding the rpm's you should be able to switch out a little pill to set it.
Old Jun 24, 2005 | 07:33 PM
migs's Avatar
Default Re: (Kendall)
Neptune.
Old Jun 24, 2005 | 07:43 PM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">And regarding the rpm's you should be able to switch out a little pill to set it.</TD></TR></TABLE>
If that's how it adjusts.
Mine is digital and just push a button sets the shift point. No pills.
Old Jun 24, 2005 | 08:11 PM
imnotted's Avatar
Default Re: (1GreyTeg)
Some also have a dial on the back that you can adjust. The pills seem to be growing obsolete.
Old Jun 25, 2005 | 06:37 AM
Black R's Avatar
25 Year Member
i have a pivot one that plugs in the cigarette lighter and gets power + reads the signal from there.
Old Jun 25, 2005 | 06:46 PM
Chris F's Avatar
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">i have a pivot one that plugs in the cigarette lighter and gets power + reads the signal from there. </TD></TR></TABLE>
No way, where'd you get that?
Old Jun 26, 2005 | 08:16 AM
Black R's Avatar
25 Year Member
Default Re: (Chris F)
japan, y0!
kengs brought it back for me on one of his trips a couple of years ago.....
https://honda-tech.com/zerothread?id=233585
Old Jun 26, 2005 | 05:44 PM
ATgrills.com's Avatar
I have a small dial in the back of my shift light!
Old Jun 27, 2005 | 10:22 AM
IVI's Avatar
IVI
Default Re: (ATgrills.com)
any of you guys have pics of your shift light?
specifically Rodney's.
Old Jun 27, 2005 | 10:32 AM
Mires's Avatar
Default Re: (IVI)
I always wanted to do an Autometer behind an AC vent. Low profile style.
Old Jun 27, 2005 | 04:45 PM
Relic1's Avatar
pick up an RPM switch for $40, buy any color LED you want with the appropriate resistor, put it anywhere you want. In the cluster works great for me.
Uberdata's shift light feature works well too.
Ej896
Honda Civic (2001 - 2005)
Apr 8, 2007 07:04 PM
markysparky
14
Jan 25, 2006 01:52 PM
j_kevin_ca
26
Oct 14, 2004 10:13 AM
jl21ah
May 4, 2004 10:51 PM
01PYTypeR#1140
May 20, 2002 09:29 AM
