Proper way to install gauges (need to install 3 of em)
Old Jun 24, 2005 | 04:45 PM
BlueShadow's Avatar
Default Proper way to install gauges (need to install 3 of em)
Hey guys,
I need to finish wiring up my gauges and I was wanting to know the best way to hook them up. I dont wanna do how I did it before or how people suggest and ghetto rig it.
Here is what I have left to wire up:
-Need to wire in the illumination lights for my boost and oil pressure gauge. So a 12V switched like my parking light., and a ground.
-Need to wire in oil pressure gauge. Need a good ground for the gauge and a 12V ignition switched. Can I share the same ground as my boost and oil pressure illumination?
-Need to wire in Nordskog temp gauge. Red wire to 12V ignition switched, and Black and Purple (dimmer) to ground. For the 12V ignition switched can I share the same one I use for my oil pressure gauge? and same thing with the ground, can I use the same grounding location as my illumination lights for boost/pressure and the oil pressure gauge?
The main thing I'm worried about is the 12V ignition switched. I want to know if I can take the wire coming from the oil pressure and water tempt gauge and join them together into one. Then from there I take the one wire and run it to my 12V ignition switched source.
TIA
Old Jun 24, 2005 | 05:57 PM
NikoZai's Avatar
Default Re: Proper way to install gauges (BlueShadow)
yeah you can join them BUT you have to know what cicuit you're tapping into. if you tap into a 12v+ switch that runs thought a 10amp fuse, you may overload that fuse and have to step up to a larger amp rating.
Old Jun 24, 2005 | 06:11 PM
BlueShadow's Avatar
Default Re: Proper way to install gauges (NikoZai)
ahh that's good to know. So if I was to fuse tap both of my gauge lights to the parking lights or headlights which I think are 10AMP I should probably go to a 15 amp fuse? or should I go to a 20 amp fuse?
And that leaves two other switched 12V sources I stil need to tap. I guess I could fuse tap one off of the ALT/SOL/VALVE fuse where I currently have a 30 amp fuse. What about the ECU fuse? can I tap off of that?
Is there something else I can do besides tapping the ALT/SOL/VALVE and ECU fuses for my 12V switched power?
Old Jun 24, 2005 | 08:45 PM
bloopie's Avatar
Constant - Radio Fuse
Illumination - Headlight Fuse
Ground - Ground
There ya go.
Dont put a higher amp rated fuse into a lower rated fuse slot. Bad things happen.
Old Jun 24, 2005 | 08:54 PM
BlueShadow's Avatar
Default Re: Proper way to install gauges (tuner.fish)
cool, I was actually thinking about using the radio/cig lighter interior fuse for my 12V switched. I wanted my gauges to go on when the parking lights are on. I checked my fuses earlier but I cant remember if there was one for parking plights or not. If there isn't I'll just fuse tap the headlights.
For the ground should I ground it to the chassis or to the engine block/tranny?
Old Jun 25, 2005 | 09:07 AM
bloopie's Avatar
Uh, like I said, do it for your headlights and they will illuminate with just one turn of your ****.. so it will be like parking lights.
tundra2000
Sep 27, 2010 06:22 PM
95dc2teg
Jan 31, 2007 10:48 AM
Themouse
Oct 3, 2006 03:49 AM
bosco500
28
Apr 25, 2005 05:07 AM
Ibuprofen
Feb 5, 2005 05:10 AM
