12:5 compression. Skunk Stage 2 or 3 cams?
I am building a LS/Vtec , with 12:5 compression. Do you think I should go with Skunk stage 2 or 3 cams? Which do you think I will be able to pull out more power from? Not necessairly just peak power, but a all around better power curve, that will result in a faster time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">skunk2 pro 1's or rockets m22xx</TD></TR></TABLE>
Agree 100%. Would be very nice with those cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JH4DC4-2GSR »</TD></TR><TR><TD CLASS="quote">i would like to know your complete setup before i can give you a definitive answer.. Valves, pistons, milling etc?</TD></TR></TABLE>
I have complete valve train. JE Pistons
Not actually a LS/Vtec. B16 with LS crank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett »</TD></TR><TR><TD CLASS="quote">Are you drag racing or street driving/ occasional drag racing?</TD></TR></TABLE>
Street Driving, but will be taking to the track atleast twice a month.
So you think the skunk2 pro 1's will make more power than the regular Stage 2 or 3's?
The pro 1's have greater lift on the non vtec lobe then the stg 2 and 3's but a slightly lower lift vtec lobe. All in all the pro 1's make alot more midrange and are a better street cam IMO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sihatch »</TD></TR><TR><TD CLASS="quote">The pro 1's have greater lift on the non vtec lobe then the stg 2 and 3's but a slightly lower lift vtec lobe. All in all the pro 1's make alot more midrange and are a better street cam IMO.
So you think i will run a better track time with the pro 1's ?
</TD></TR></TABLE>So you think i will run a better track time with the pro 1's ?
no, pro1's are a street/strip cam, if your going all out drag strip or trying to get the best q/mile time then go with the 3's...... its been my experience that 8 out of 10 people on h-tech all motor forum have street cars and always recommend cams that make good midrange numbers instead of power from 7-9k which is more important at the strip, just my opinion, goodluck.
Pro1's or M22xx, unless this is just a drag motor that is going to run between 7500-9000. Skunk 3's make more power from 8200 rpm up, the others more below, up to 15 BHP.
bump,i am wondering the same thing but i would like to know which cams will make more mid-range & top-end power than all the cams that everybody suggested........
you'd be happy with skunk 2's... skunk 3's need more tuning.. skunk 2's idle pretty much stock .... so it is a great street cam...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">Some Spock STG. 5's depending on the rest of your build. Avail from Rocket, skunk, RLZ, or me. Expensive though.</TD></TR></TABLE>
Don, I didnt know these top secret cams were available yet
S2S3's for dragging...you're gonna hopefully be in Vtec all the time, and the 3's make more power. Only go Pro1's or S2's if you plan to shift @ 6000 RPM's
Everyone is right Pro1's and do not use the specs that skunk recomends you want like a 101 int CL / 108 exh CL. they recomended 103 CL on both and it loses torque and power. they make awesome torque. the skunk 3's have too much duration in my opinion i feel that you loss some inlet charge out the exh because of the cyl head's steep pent roof design.
Dat1BVtecN
30
May 10, 2006 08:49 AM
Deetz
21
Jul 12, 2004 06:11 AM
