sk2 stage 2 cams
Old Jun 24, 2005 | 01:27 PM
redlseg's Avatar
Default sk2 stage 2 cams
when i put these cams in my vtec head do i need to readjust my valves?
Old Jun 24, 2005 | 01:40 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: sk2 stage 2 cams (h-tman)
Anytime you change to aftermarket cams you should do a proper valve adjustment. I hope you have also upgraded your springs and retainers.
Old Jun 24, 2005 | 02:01 PM
Yambor's Avatar
Default Re: sk2 stage 2 cams (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">Anytime you change to aftermarket cams you should do a proper valve adjustment. I hope you have also upgraded your springs and retainers.</TD></TR></TABLE>
Old Jun 27, 2005 | 05:36 AM
StorminMatt's Avatar
Actually, any time than ANY cams are installed, valve adjustment is necessary. This is even the case if you are just reinstalling the same cams you took out.
Old Jun 27, 2005 | 06:53 AM
Default Re: sk2 stage 2 cams (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, any time than ANY cams are installed, valve adjustment is necessary. This is even the case if you are just reinstalling the same cams you took out.</TD></TR></TABLE>
Please tell me how valve lash changes when removing and installing the exact same cams?
J-Spot
22
Sep 27, 2007 10:15 AM
RiceFed
Dec 10, 2006 05:52 PM
hondatuner20
Jun 7, 2005 01:52 PM
youngvedder
Jan 20, 2005 04:35 PM
SymphonyX
Jun 11, 2003 07:54 PM
