how to get spark plug out with the rubbery socket??
i got to the point of unwreching the the plug got it lossend and then i couldnt get it out i was just using a 16mm socket. but yea i cant get it out like it wont lift up .should i just buy a socket with the rubber in it or what ?
The rubber piece inside the socket basically ensures that you don't crack the porcelain on the spark plug...if you do, good luck. I would say buy one as they are not that expensive and you will use it a lot, its better to have the right tools for the job instead of making do.
what i did when i didn't have the right socket, i would loosen the plug and then use needle nose pliers to pick out the spark plug.
just get the correct socket, it shouldn't cost more than $5.00.
pityocamptes
Sep 10, 2015 09:55 PM
JDM_SOHC
24
Aug 13, 2008 03:49 AM
