Where does this hose go>>??? HELP ASAP!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aziantegger10 »</TD></TR><TR><TD CLASS="quote">maybe right above your wrist?</TD></TR></TABLE>
it doesnt reach.
it doesnt reach.
What throttle body are you using and did it come with the manifold or did you change throttle bodies? The hose goes to the throttle body, where there already appears to be a hose that is looping down under the TB. Where is that hose going? What should happen is that the hose you have in your hand should go to the TB, and then there should be another hose coming off the otherside of the TB that goes to the IACV on the manifold.
DO NOT PUT IT ON THE TOP OPEN PORT OF THE TB!!! That is a vacuum connection for the EVAP system
ok, ive followed the hose and ended up at the circle..
i tried connecting the hose to #1, but #1 leads to the engine block.
Modified by kobeRy_si at 2:50 PM 6/24/2005
the hose above in the red circle leads to the underside of the throttle body. if you already have something else connected to the throttle body in that spot then you have something wrong.
Modified by RTW DC2R at 5:38 PM 6/24/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">the hose above in the red circle leads to the underside of the throttle body. if you already have something else connected to the throttle body in that spot then you have something wrong. </TD></TR></TABLE>
EXACTLY!! Thats what I was trying to say but I guess it wasn't clear...
djviet2000
10
May 9, 2008 06:28 AM
JDM_EK_621
Mar 18, 2007 06:05 PM
Maverik4k
Aug 1, 2005 05:54 AM
