ABS malfunction please HELP!!!
Old Jun 24, 2005 | 09:03 AM
dIveR$E[323]'s Avatar
Default ABS malfunction please HELP!!!
it started yesterday on the way to the Eagle Rock meet. i was on the 2 fwy, gunned it. i was on 3rd gear 6500 rpm, when the abs light flashed and went on and off the brakes (thats w/o me steppin on the brakes at all). it did the same thing when i was on 1st gear right before it hits redline. i decided to reset the ECU and the ABS unit, unhooked the battery. no changes . normal driving is ok. cant really diagnose it because its not throwin a check engine light. need HELP!!!!! LMK if you guys have any idea on how to fix this.
i did a search, but for some reason its not givin me anything (archived).
Old Jun 25, 2005 | 07:15 PM
Default Re: ABS malfunction please HELP!!! (dIveR$E[323])
help!!! losin sleep over this... please!
Old Jun 26, 2005 | 02:31 PM
need answers, please... help!
Old Jun 27, 2005 | 07:26 AM
paaaaawwwt!
Old Jun 27, 2005 | 11:24 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dIveR$E[323 &raquo;</TD></TR><TR><TD CLASS="quote"> the abs light flashed </TD></TR></TABLE>
What trouble code does it have stored?
Old Jun 27, 2005 | 01:30 PM
Default Re: ABS malfunction please HELP!!! (Chiovnidca)
it just flashed twice and braked (jerked). some times the abs lights would stay on for a while. but the next time i start the car it was already gone.
Old Jun 27, 2005 | 02:18 PM
B_CRUZ!'s Avatar
you can still pull the code. it keeps it in memory y0!
Old Jun 27, 2005 | 02:56 PM
Default Re: ABS malfunction please HELP!!! (B_CRUZ)
i just took it to the dealer to get it scanned. they found nothin stored in the memory. i now owe $45 for nothin, lol. aint that a bioooootch!
Old Jun 27, 2005 | 03:08 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dIveR$E[323 &raquo;</TD></TR><TR><TD CLASS="quote"> i decided to reset the ECU and the ABS unit, unhooked the battery. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dIveR$E[323 &raquo;</TD></TR><TR><TD CLASS="quote">i just took it to the dealer to get it scanned. they found nothin stored in the memory. </TD></TR></TABLE>
Has the light come on since you reset it?
Old Jun 27, 2005 | 06:21 PM
B_CRUZ!'s Avatar
why couldn't you pull your own damn code? paper clip too expensive for you?
Old Jun 27, 2005 | 06:54 PM
rainforest's Avatar
right front wheel speed sensor do a resistance test to check for a open in the wss
Old Jun 28, 2005 | 08:16 AM
Default Re: ABS malfunction please HELP!!! (rainforest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Has the light come on since you reset it?</TD></TR></TABLE>
yes, when it brakes on its own it would stay on for a good 5 seconds. it happens most of the time when im on high rpm or when im making a turn on 2nd gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B_CRUZ &raquo;</TD></TR><TR><TD CLASS="quote">why couldn't you pull your own damn code? paper clip too expensive for you?</TD></TR></TABLE>
lol! paper clip is not too expensive for me, i just didn't know how. maybe you can show me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest &raquo;</TD></TR><TR><TD CLASS="quote">right front wheel speed sensor do a resistance test to check for a open in the wss </TD></TR></TABLE>
how do i do a resistance check? "for a open in the WSS" like a crack/visible damage?
i tried unpluggin the ABS unit. drove it w/o the abs, seems like its dragging. it felt like i was driving w/ the e brakes not all the way down.
thanks for all your help, i really appreciate it
Old Jun 28, 2005 | 09:48 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dIveR$E[323 &raquo;</TD></TR><TR><TD CLASS="quote">]lol! paper clip is not too expensive for me, i just didn't know how. maybe you can show me... </TD></TR></TABLE>What year/model? Your sig says DC, so it's an Integra? Check the sticky at top of Integra forum 'ECU codes' or whatever it's called. The ABS error code lists changes with years & models, so ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dIveR$E[323 &raquo;</TD></TR><TR><TD CLASS="quote">]how do i do a resistance check? "for a open in the WSS" like a crack/visible damage?</TD></TR></TABLE>Use a multi-meter to measure resistance of the sensor. A broken wire is an 'open circuit' which will measure infinitely high resistance. Don't bother doing this until you read the ABS error code. If it's the code for the right-front wheel sensor then you can check it out.
edit...
OK they changed it all around since I haven't been to the Integra forum awhile. It's linked off the FAQ sticky. Here it is. Scroll down to ABS codes.
https://honda-tech.com/zerothread?id=978933
Old Jun 28, 2005 | 10:18 AM
Default Re: ABS malfunction please HELP!!! (JimBlake)
She's a '96 integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">What year/model? Your sig says DC, so it's an Integra? Check the sticky at top of Integra forum 'ECU codes' or whatever it's called. The ABS error code lists changes with years & models, so ??
problem is i dont know how to retrieve the code. Dealer came up w/ no code either... thanks for the link!
Old Jun 28, 2005 | 11:03 AM
JimBlake's Avatar
The link says how to retrieve the code, along with the error code lists. I know it covers '96 Integra...
Old Jun 28, 2005 | 12:10 PM
ill try to retrieve codes as soon as i get the car back... good lookin out homie!
*EDIT* no codes retrieved
it looks normal, doesn't light up until i reach either high rpm or turning on 2nd gear...
Modified by dIveR$E[323] at 3:17 PM 6/28/2005
Old Jun 29, 2005 | 07:47 AM
the dealer told me there was nothing they can do coz i have a different ECU on there. he said it had nothin to do w/ the brakes. for some reason, the motor cuts off when im makin a turn on 2nd gear or sometimes in high rpms...
Old Jun 29, 2005 | 07:58 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dIveR$E[323 &raquo;</TD></TR><TR><TD CLASS="quote"> for some reason, the motor cuts off when im makin a turn on 2nd gear or sometimes in high rpms... </TD></TR></TABLE>
The engine cuts off? Is that the same time the ABS light comes on?
Old Jun 29, 2005 | 08:09 AM
^^^ yes, same time. it only comes on for a good second though...sometimes the "maintenance req'd" light comes on too. don't really understand why...
Old Jun 29, 2005 | 08:20 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dIveR$E[323 &raquo;</TD></TR><TR><TD CLASS="quote">]^^^ yes, same time. it only comes on for a good second though...sometimes the "maintenance req'd" light comes on too. don't really understand why... </TD></TR></TABLE>
Do you have a big ol wad of keys swinging around? Try taking the ignition key off the ring and driving with it by itself. Does it still act up?
Old Jun 29, 2005 | 08:31 AM
i dunt think thats the problem, it just started doin it. i've been driving it along w/ the other keys w/o problems before. i'll try it anyway n let you know...
Old Jun 29, 2005 | 07:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dIveR$E[323 &raquo;</TD></TR><TR><TD CLASS="quote">]i dunt think thats the problem, it just started doin it. i've been driving it along w/ the other keys w/o problems before. i'll try it anyway n let you know...</TD></TR></TABLE>
it wasnt the keys... any more ideas?
Old Jul 1, 2005 | 07:17 AM
help!
Old Jul 5, 2005 | 09:39 AM
problem solved! it wasn't teh brakes. it was cutting of fuel. changing the fuel filter fixed teh problem. the ABS light goin on n off is still a mystery. nothin major though. thanks for all the help!!!
LukieLuc
Mar 22, 2007 11:05 AM
