does a bigger valve leash make more noise?
Old Jun 24, 2005 | 03:22 AM
an2ny888's Avatar
Default does a bigger valve leash make more noise?
i used the reccommended 8,9 valve leash on my buddy club cam install. when i start the car cold, i hear this weird sound for an instant, then it goes away. it sounds like the engine is running without oil for that instant. is this noise a direct result of the bigger valve leash?
Old Jun 24, 2005 | 08:09 AM
JDAMC's Avatar
Default Re: does a bigger valve leash make more noise? (an2ny888)
Did you change valve springs too?
Old Jun 24, 2005 | 02:50 PM
Yambor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">i used the reccommended 8,9 valve leash on my buddy club cam install. when i start the car cold, i hear this weird sound for an instant, then it goes away. it sounds like the engine is running without oil for that instant. is this noise a direct result of the bigger valve leash?</TD></TR></TABLE>
that and check your oil!
Old Jun 24, 2005 | 02:57 PM
PURPLETERROR aka BIGMATT's Avatar
You will get a bit more noise from looser valvelash, you may want to consider running a good 10w40 also depending on how you drive your car.
Old Jun 24, 2005 | 06:34 PM
an2ny888's Avatar
Default Re: does a bigger valve leash make more noise? (PURPLETERROR)
yeah i checked the oil level, im currently using 5w-40 motul oil. i used full itr valvetrain
Old Jun 26, 2005 | 07:53 AM
moto1320's Avatar
It's cold start clatter, not from your valve lash. In regards to tightening it up just to quiet a motor down....you'll never hear one burning either. I'll happily deal with the ticking, as if you can hear it over the intake and exhaust noise anyway. Which set of BC's are you running on ITR springs?
Old Jun 26, 2005 | 03:53 PM
93hatchin's Avatar
I have the same problem. what is it? hopefully not a rod bearing..... Its really scarey.
Old Jun 26, 2005 | 06:42 PM
an2ny888's Avatar
Default Re: does a bigger valve leash make more noise? (moto1320)
i'm using bc3+ cams with the itr valvetrain at stock rev limit. the sound is most audible when the engine is cold, its not present when starting with a hot engine. the thing is i didnt hear this sound at all before i swapped cams
Old Jun 27, 2005 | 08:09 PM
sleeperb16a's Avatar
I had the same problem with my B16A...clatter at start up in the mornings. Switched to genuine Honda oil filters and the problem disappeared. I guess the Anti-Drainback valve really works in these filters.
Old Jul 2, 2005 | 03:30 AM
an2ny888's Avatar
Default Re: does a bigger valve leash make more noise? (sleeperb16a)
now i'm beginning to think it could be more than just valve clatter, maybe i have a spun bearing? the engine sounds like its running without oil for a second when you first start it, how do i diagnose this?
Old Jul 2, 2005 | 07:56 AM
bosco500's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">now i'm beginning to think it could be more than just valve clatter, maybe i have a spun bearing? the engine sounds like its running without oil for a second when you first start it, how do i diagnose this?</TD></TR></TABLE>
If you've spun a bearing, the motor would be locked up.
Are you running an oil cooler or remote oil filter?
If so, the oil could be running back into the pan from the lines when the car is shut off. If not, its just valve ticking. If it was a weak bearing, it would make the sound all the time.
Old Jul 2, 2005 | 09:14 AM
an2ny888's Avatar
Default Re: does a bigger valve leash make more noise? (bosco500)
i'm using the stock oil system, seen too many guys have problems when running oil coolers or remote setups. could the noise be rod knock? are my symptoms consistent with this?
Old Jul 2, 2005 | 11:02 AM
bosco500's Avatar
No. You will hear a rod knock consistantly with engine rpm's.
Old Jul 2, 2005 | 01:23 PM
jdmHboy's Avatar
If you used the recommended valve lash, and did a good job, everything is fine. I think you're freaking out about nothing. Honda motors are always a little chattery. My gsr used to do the same thing. If something serious was wrong with the car (spun bearing) the symptoms would be a lot worse, trust me.
Old Jul 2, 2005 | 08:12 PM
an2ny888's Avatar
Default Re: (jdmHboy)
ok tnx for all the feedback
roycivic92
11
Oct 9, 2009 06:16 PM
sector001
Oct 13, 2006 12:09 PM
For_Sale
Jul 12, 2006 10:50 AM
adam_reiland
Apr 26, 2005 07:56 PM
