Running Vtec wires on a Non-Vtec engine wiring harness
Old Jun 24, 2005 | 12:46 AM
ek9vboi2's Avatar
Default Running Vtec wires on a Non-Vtec engine wiring harness
I've been searching and searching. Either I don't understand what the heck some people are talking about or... i'm a little slow. Anyways, doing LS/Vtec for a friend and the inside cabin wires are ran correctly.
Problem is:
I have a 94 OBD1 LS engine harness. I'm trying to run the Vtec wires (3 wires?) into the harness, 1 going to the Vtec soleniod, 1 going to the pressure sensor and then 1 other wire...no idea where it goes.
Here is a picture to explain it:
Does the black wire from the pressure sensor go to a grounding point?
Also, can someone check to see if I have the wiring correct on the plug for the pressure sensor too please. Thanks in advance!
Old Jun 24, 2005 | 07:31 AM
IHateJDM's Avatar
Default Re: Running Vtec wires on a Non-Vtec engine wiring harness (ek9vboi2)
black wire is pressure switch ground. I can't see the pics (firewall at work), what ecu are you using? for most obd1 you want:
solenoid (one wire plug) - A4
Pressure switch - D6
Pressure switch ground - A26 (or with P28, can be grounded to the head)
Old Jun 24, 2005 | 10:02 AM
ek9vboi2's Avatar
Cool looks like I ran everything properly. I grounded the black wire to the head, ran it into the grounding spot/part on the harness.
Old Jun 24, 2005 | 07:20 PM
Dragline's Avatar
Default Re: (ek9vboi2)
What ecu are you running? you may also need to wire in A knock sensor.
Old Jun 24, 2005 | 07:28 PM
ek9vboi2's Avatar
How do I do that? Using a stock p28.
Old Jun 24, 2005 | 07:32 PM
Dragline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9vboi2 &raquo;</TD></TR><TR><TD CLASS="quote">How do I do that? Using a stock p28.</TD></TR></TABLE>
You don't with A p28
Old Jun 24, 2005 | 07:44 PM
ek9vboi2's Avatar
cool, thanks a lot guys.
03EM2guy
Apr 19, 2011 01:17 PM
RiverRat2
Sep 27, 2009 05:02 PM
slow_cx
Aug 22, 2007 11:11 AM
89D15CRXDX
12
Mar 22, 2007 04:40 AM
zex_cool
Sep 19, 2006 10:11 AM
