HOW HIGH CAN I REV MY STOCK LS RODS
swap out your rod bearings for factory b16a bearings of the same color as they are a trimetal bearing and can take more abuse than the ls bearings. Upgrade to arp rodbolts and you should be fine.
purple terror i gotta hand it to u ,ur a ****** genoius when it comes to motors,if we didnt talk **** to each other id say u can biuld my motor and i can race since ur fat and tall and would slow the car down
id never rev a ls to 8grand. Think about the rod ratio , 1.54? thats low.. too low for 8grand. bearings and rod bolts too.
Sure you can rev a ls to 8grand, how much, how often and how long is the question..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crixzc »</TD></TR><TR><TD CLASS="quote">I donno about this one, the ls rods are different from the B16a's. No oil hole sounds like bad news to me.</TD></TR></TABLE>
Exactly, you dont know about this one. What are you talking about"no oil hole" ls and b16a rod bearings are the same size, the b16a's are a better material. Acl's are ok if you are within the green tolerance range. I prefer to stick with oem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">swap out your rod bearings for factory b16a bearings of the same color as they are a trimetal bearing and can take more abuse than the ls bearings. Upgrade to arp rodbolts and you should be fine.</TD></TR></TABLE>
ARP rod bolts will save you life. I use ACL but OEM's(B16) are fine.
I've reved my LS with stock rods and bolts to 9500rpm without a problem for over a year.
I think it all depends on the amount of miles on the motor if it has low miles then go for it.
If it has high miles then rebuild it.
I have kinda the same question, but I'm loooking for RELIABLE rev lol, I dun wanan do 9000 because it can take it, I wanna do 8 if it's not killing my motor. I only have on car, and it's this one. IIf I blow the motor.. I'm screwed lol. I dun have the $ right now for a second car either. I need my setup to be reliable. This was good info though.
i thought ls and b16 rod bearing were the same
but anyways i had the machine shop notch the rods so i can run the smaller gsr/itr rodbearings with the factory coating on them. i also run arp rod bolts and had the rods resized for the bolts
I also would want a reliable ls/vtec motor. Mine would only be a mild build with 8k in mind as well. Do I really *need* new rods and pistons? Or can I just replace the rod bolts, headstuds, oil pump, water pump, ect. ect. Or is there more to it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crimsonafterlife »</TD></TR><TR><TD CLASS="quote">I also would want a reliable ls/vtec motor. Mine would only be a mild build with 8k in mind as well. Do I really *need* new rods and pistons? Or can I just replace the rod bolts, headstuds, oil pump, water pump, ect. ect. Or is there more to it?</TD></TR></TABLE>
No you don't need new pistons, OEM honda pistons are great. Pick up a set of P30 pistons, Rod bolts, GSR/ITR Oil pump and water pump, you'll be just fine.
dem0nk1d
Feb 4, 2007 09:18 AM
Flexin5
Mar 1, 2006 07:54 PM
