Best engine for 94 ex
Old Jun 23, 2005 | 10:16 PM
pbgod888's Avatar
Default Best engine for 94 ex
Hey guys I dont know much about hondas but I guess if I did I would not be on here asking questions. I have heard that the best thing to do for a honda if you a willing to spend the time and money is to swap the engine out. Well I need to ask the question of what is the "best" engine to swap the stock one out with? I also need to swap the tranny from a to m. Also where is a good place to get the engine and tranny? 1994 Accord EX vtec 4cl. Thanks and sorry for asking the question that has been probably asked the most.
Old Jun 24, 2005 | 06:25 AM
br0nx finest's Avatar
Banned
Default Re: Best engine for 94 ex (pbgod888)
If I were you, I'd go with a JDM H22 type S, those are higher compression than regular non type S to squeeze out a couple more horses, + a few more differences, LSD transmission, you'd be making around 210-220 at the flywheel
I'd suggest getting the ECU to match, but I'm not sure what it is, I have more experience with USDM H22s.
I'm sure someone else will add more helpful info., I'm just trying to get the ball rolling for you
Old Jun 24, 2005 | 06:54 AM
NAiL05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbgod888 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys I dont know much about hondas but I guess if I did I would not be on here asking questions. I have heard that the best thing to do for a honda if you a willing to spend the time and money is to swap the engine out. Well I need to ask the question of what is the "best" engine to swap the stock one out with? I also need to swap the tranny from a to m. Also where is a good place to get the engine and tranny? 1994 Accord EX vtec 4cl. Thanks and sorry for asking the question that has been probably asked the most. </TD></TR></TABLE>
It depends you want to go NA or FI. There are a couple threads bout this you should try searching.
Old Jun 24, 2005 | 07:13 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Best engine for 94 ex (NAiL05)
LS1
Old Jun 24, 2005 | 11:27 AM
freaker's Avatar
Default Re: Best engine for 94 ex (Vt4cPwn35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 &raquo;</TD></TR><TR><TD CLASS="quote">LS1
Werd!
Old Jun 24, 2005 | 12:23 PM
Nick H's Avatar
New User
Default Re: Best engine for 94 ex (br0nx finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by br0nx finest &raquo;</TD></TR><TR><TD CLASS="quote">If I were you, I'd go with a JDM H22 type S, those are higher compression than regular non type S to squeeze out a couple more horses, + a few more differences, LSD transmission, you'd be making around 210-220 at the flywheel
I'm sure someone else will add more helpful info., I'm just trying to get the ball rolling for you </TD></TR></TABLE>
if he were to do this, he'd have to convert his entire car to obd2, which would be one of the biggest pain in the asses in world...i really don't see why you'd go with the type s for an extra 2 grand either...
the most popular engine swap for accords is either the h22 or h23...the h22 is a 2.2 liter 4 cylinder dohc vtec motor that revs to 7200 (7400 jdm) making 190 hp (200 jdm) and 156 lb/ft (160 jdm)...the h23 is a 2.3 liter 4 cylinder dohc non-vtec motor that revs to 6700 rpm's making 160 hp and 156 lb/ft tourque...
it really depends on what you want out of your car to determine which motor is best for you...the h22 is not as boost friendly as the h23 or original f22 if that is the direction you want to go...however, the h22 is a good platform to start with if you want an all motor setup that makes respectable power...
good luck
chinolal
Oct 27, 2019 04:34 PM
wsotojr
Jul 8, 2007 12:09 PM
tarlik
Oct 8, 2005 12:48 PM
blazintildadeat
Sep 7, 2005 07:26 AM
exclusive_vtec
14
Jun 28, 2004 06:45 AM
