00 Prelude sh seats installed in my crx!
Old Jun 23, 2005 | 08:36 PM
mekanism's Avatar
Default 00 Prelude sh seats installed in my crx!
I have been trying to sell these seats for over a year but no one was interested so I decided to do whatever it took to get these seats in my car. Another reason is my stock seats were just beat. Everytime I got in the car I would get stabbed from a piece of metal sticking out of the drivers seat. Anyway, after reading how people simply swapped out the seat pans I decided to give it a try.
Here is the passenger crx seat and the prelude seat. First things first, remove the cushions from the frames-
You have to cut all of the hook rings inorder to remove the crx cushion. The prelude uses plastic clips that are sown to the fabric.
bare crx pan-
bare prelude pan-
Amazingly the back part of the prelude seat bolted right up the crx recline bracket. I just had to peel back some of the upholstery to access the bolts.
I used some safety wire and twister pliers to secure the prelude cushion to the crx pan. The prelude bottom cushion seems to be longer from front to back and doesnt sit very well in the crx pan but it works fine. I dont think my fat *** will notice
Here are the finished seats in my car-
There are a few things I dont like about this seat swap. For one the seats are set in a permanent gangsta lean even when set to the most upright position. Its not bad though and I think I can live with it. Another thing I dont like about the prelude seats are the fact that they are much more narrow than my crx seats. I am a short stocky guy with really wide shoulders so it is hard finding comfortable stock seats that I fit in. Anyway, I hope this gives a little insight as to what's involved in swapping seat pans. This was much easier than welding and fabbing up brackets. I did both seats in about 4 hours.
Modified by mekanism at 10:05 PM 6/23/2005
Modified by mekanism at 10:19 PM 6/23/2005
Old Jun 23, 2005 | 08:38 PM
vegaskurt's Avatar
Default Re: 00 Prelude sh seats installed in my crx! (mekanism)
You are the man!!!
Old Jun 23, 2005 | 09:28 PM
JapJunkie's Avatar
Default Re: 00 Prelude sh seats installed in my crx! (vegaskurt)
Good ****. ur interior is clean holmes.
Old Jun 23, 2005 | 09:31 PM
CRX_1.8T's Avatar
Wow... damn... looks great brother!
Old Jun 23, 2005 | 10:28 PM
mekanism's Avatar
Default Re: 00 Prelude sh seats installed in my crx! (CRX_1.8T)
Thanks guys!
Old Jun 23, 2005 | 11:59 PM
SFlCrx's Avatar
yea that looks great my driver seat was beat so i swaped it with the passenger and it is also stuck in gangsta mode but alot wrose then yours probably
Old Jun 24, 2005 | 05:51 AM
crx_88_si's Avatar
tried shimming up the rear mounting bolts of the seats to reduce the "gangsta" feel?
Old Jun 24, 2005 | 06:27 AM
Its me DUB's Avatar
Dude, they look great. Very clean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mekanism &raquo;</TD></TR><TR><TD CLASS="quote">Another thing I dont like about the prelude seats are the fact that they are much more narrow than my crx seats. I am a short stocky guy with really wide shoulders so it is hard finding comfortable stock seats that I fit in. </TD></TR></TABLE>
Didn't you try them out before you went through all the work to put them in? Why did you pick these if you had never actually sat in them? Don't worry bout it man...you'll either get used to it or else find some that fit better and swap those in - you know how to do it now so it will be cake!
Old Jun 24, 2005 | 06:46 AM
Voodooboy520's Avatar
You should put something like a How To in the title, to make it easier for others to find when searching.
Old Jun 24, 2005 | 07:16 AM
HumanResource's Avatar
They look heavy
Old Jun 24, 2005 | 07:29 AM
bagpipe goatee's Avatar
you have a crx with si seats, but it has civic si door panels?
not complaining, nice car by the way.
Old Jun 24, 2005 | 07:57 AM
civiccrx21's Avatar
they dont look to bad , I remember the 92-96 lude seats looked nice as well , nice job bro
Old Jun 24, 2005 | 07:58 AM
mekanism's Avatar
Default Re: (bagpipe goatee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doitdub &raquo;</TD></TR><TR><TD CLASS="quote">Dude, they look great. Very clean
Didn't you try them out before you went through all the work to put them in? Why did you pick these if you had never actually sat in them? Don't worry bout it man...you'll either get used to it or else find some that fit better and swap those in - you know how to do it now so it will be cake! </TD></TR></TABLE>
I got these seats from a friend for very cheap a while back with the intention of selling them. I had sat in them on the ground and they felt ok. I think they feel alot skinnier because I am used to my crx seats which are very worn out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">you have a crx with si seats, but it has civic si door panels?
not complaining, nice car by the way.</TD></TR></TABLE>
They are actually 91 crx hf or dx panels. Civic panels dont fit in crx's. The panels that have crx embroidered into them are from Si models. My car is an Si, but I swapped panels because these panels had the cutout for a tweeter already.
Old Jun 24, 2005 | 09:02 AM
Its me DUB's Avatar
Default Re: (mekanism)
I got these seats from a friend for very cheap a while back with the intention of selling them. I had sat in them on the ground and they felt ok. I think they feel alot skinnier because I am used to my crx seats which are very worn out.</TD></TR></TABLE>
or your old seats got worn out from the drive to Burger King everyday.
just playin
Old Jun 24, 2005 | 11:10 PM
They are actually 91 crx hf or dx panels. Civic panels dont fit in crx's. The panels that have crx embroidered into them are from Si models. My car is an Si, but I swapped panels because these panels had the cutout for a tweeter already.</TD></TR></TABLE>
well, most dx panels i've seen and all hf panels don't have the fabric in that section.
and, other than the clips in the back, which can be switched over, crx and hatch panels are the same (if you stay with the same seatbelt location, of course)
only reason i know is because i have crx si panels in my hatch dx. its funny how they panels say "CRX" on them when it's a hatch.
Old Jun 25, 2005 | 11:50 AM
CRX_DOHC_ZC's Avatar
looks great man!! good work
Old Jun 25, 2005 | 12:49 PM
Burlyirishdude's Avatar
Default Re: (CRX_DOHC_ZC)
damn that sexy to the extreme.
Old Jun 25, 2005 | 01:39 PM
jedubz's Avatar
Wicked clean brotha!
Old Jun 25, 2005 | 01:57 PM
jamclaur's Avatar
I'm into it, I can't believe ow clean you interior is... I need to get on the ball cleaning mine, but engine up grades keep calling in my ear...
Old Jun 25, 2005 | 06:37 PM
mekanism's Avatar
only reason i know is because i have crx si panels in my hatch dx. its funny how they panels say "CRX" on them when it's a hatch.</TD></TR></TABLE>
That's weird I thought the hatch doors were longer. I also forgot that dx and hf models didnt have fabric on the panel. I guess my door cards are special!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamclaur &raquo;</TD></TR><TR><TD CLASS="quote">I'm into it, I can't believe ow clean you interior is... I need to get on the ball cleaning mine, but engine up grades keep calling in my ear...</TD></TR></TABLE>
My interior isnt that clean, you havent seen the back. My rear shelf is missing and the rear compartment is really crappy. The only nice part of the interior are my new seats and the new carpet, and the dash is decent. But none the less thanks for the comments!
Old Jun 25, 2005 | 07:01 PM
Rickdogg's Avatar
looks good
Old Jun 26, 2005 | 01:20 PM
ServiceAdvisor's Avatar
More pics of that cars exterior/interior.
Old Jun 26, 2005 | 01:45 PM
mekanism's Avatar
Default Re: (DOHCZCCRXSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCZCCRXSi &raquo;</TD></TR><TR><TD CLASS="quote">More pics of that cars exterior/interior. </TD></TR></TABLE>
Some pics of my car-
My new engine, freshly painted bay and wire tuck-
Old Jun 26, 2005 | 05:36 PM
MoogaMoogaMan's Avatar
nicce
Old Jun 26, 2005 | 05:43 PM
bigbusiness's Avatar
clean
